My focus the last few decades has been on clocks of European origin. However, I occasionally make an exception.
Last week I bought an Ansonia Triumph from a 94 year old woman in a local suburb. The condition of the case was so good I questioned it's authenticity. She said she owned the clock "since before the war", didn't know the maker, and insisted I take her vial of special clock oil to keep it running (it wasn't).
I discovered later she dipped the key into the oil (or whatever it is) before winding.
Needless to say, the movement had more dried, crusty oil on it than grandpa's Hoyt Clagwell tractor. Oil had dripped from the winding arbors onto the lower parts of the movement, the coil gong and alarm bell. Some of this crusted oil took the ultrasonic along with a Dremel brush to remove. Some of the staining remained. The good part is the coated, crusted parts looked well preserved.
During service I discovered a few broken lantern pinions. This was after using a dental pick to remove the grunge between and over them.
After cleaning it up, the clock turned out to be pretty nice. Apparently Ansonia made this model for many years. Can anyone provide a date estimate for when it was made? My guess is 1920s due to the oak and case condition. I know most of the early models were dark wood.
A few pictures:
The clock as found
Her special vial of oil
I assume the front glass is a replacement, although there is no evidence the original door trim has been removed. In addition, this clear glass is wavy. Comments?
The movement is in good shape. The time spring looks to be a replacement (T2 lantern pinion damage). Can this be dated or were all their movements the same?
Metal ornamentation appears to have an unusual coating. Paint??
A little oil sludge and a few broken pinions.
I'm pleased with how it turned out.
Comments appreciated.
Jim
A few pictures:
The clock as found
Jim
