I purchased this Ansonia short drop 8 day clock a few days ago at an antique mall about 100 miles from here. Other than the silver paint on the trim, the case looked in good shape and the clock was running in the store. For some unknown reason, I did not remove the face to look at the movement. Theface was labeled Ansonia Clock Company, New York. The remains of the label inside agreed with the label.
When I brought it home and hung it on the wall, I needed to put it in beat. When I removed the face, I saw the movement was in the case at an angle. The distance to the winding stem was correct; the movement had been manufactured with the winding stem directly below the hands.
I am certainly not an expert on Ansonia clocks (or any others, for that matter), but I have never seen a movement mounted at an angle like this. I do not see any extra holes for the screws. Contacted the seller and he thinks it is all original. The movement is unmarked, except for a "10" stamped into the front plate.
Has anyone seen this? Is it common?
Thanks, Mike
Thanks, Mike
