I need detailed drawings or good photos of the missing connection link from the ships wheel to the verge for this clock. The arm that comes up off the verge looks to be unaltered and original as it is a flat piece of brass collared onto the verge shaft. The pin in the end looks to be brass. The wheel is the correct stamped out brass light weight unit not one of the later cast reproduction units.
It appears the connector link would be some form of forked unit friction fit onto the wheel shaft that fits over the pin and is free to move back and forth causing the wheel to move when the clock is running. It would of necessity need to be a low friction connection or the power loss would cause the clock to stop.
If anyone has one of these that runs the full eight days and can supply the requested information it would be most appreciated
