Ansonia Capitol Springs
rfh11
Dec 13, 2008
132
Hello,
I recently purchased a Ansonia Capitol spring wound time only. Both springs were broken. What I came up with for the old springs is 7/16" x .015 x 96". My question is will a 1/2" x .015 x 96" work? Or would a 7/16" x .014 x 72" work better. Would the last spring run for 8 days? Also would anyone have any of the finials? Missing the top center and bottom left-rightk- and center.
Thanks,
Randy
46,425
1,858
If the springs main wheel will allow for the 1/2", I'd do that. The shorter spring will run less time.
harold bain
40,853
175
72
Jewels, it provides more power than a single spring, as both springs drive the same large lantern pinion. IBM (and earlier Seth Thomas) used this arrangement to drive time recorders. Also ST # 10 movements used in ships clocks used dual springs.
harold bain
40,853
175
72
Some, such as Seth Thomas's model 86 movements, run longer (15 or 30 days, depending on the model). These often drive heavy pendulums, requiring the power of two springs.
harold bain
40,853
175
72
Hello,
Thanks,
Randy
Randy, our mainspring sticky lists these springs as 3/8 x . 017 x 96", which is Timesavers part # 16866.
Hope this helps.
165,482
1,440,548
86,256
eeclone
2,873
