R. Croswell
What do you guys think of this?:
Silver Bearing Solder Paste
Done. Spoke with Richard yesterday.Contact Richard Cox at Fendley & Cox Antique Clocks
Probably ok. More important than what solder you use is your technique. Both parts must be freshly cleaned and free of all oxidation, and both parts must be raised to soldering temperature, nothing can move until the solder has set and cooled.
That saddle is pretty tight. I don't think I have the tools/ability to move it that precisely. What is the best method of moving the saddle such a small amount accurately?A little to much drop onto the entrance pallet. But that's an easy adjustment, just move the pallet saddle pin up a scosh. One 'scosh' would be about .004" or 1/10 mm.Willie X
I always wondered how much a scosh was, thanks!A little to much drop onto the entrance pallet. But that's an easy adjustment, just move the pallet saddle pin up a scosh. One 'scosh' would be about .004" or 1/10 mm.Willie X
You have a right to be nervous. See picture (red arrow) you have very little lock. Locking on the tip of the pallet. Very close to slipping and spinning free and wrecking the escape wheel. But look at the blue arrow, looks like "the bone" itself is bent from previous adjustments (rivet did not move) any further bending of the bone without the rivet slipping could cause it to snap off - yes, I would be nervous.I'm a bit nervous about moving the pallet dog bone. What are the consequences of not moving it?
You say better, does that mean it's good where it is, or do I need to go closer? Thanks.much better lock
This clock is another Frankenstein. It sure has been a learning experience. I'm fixing this for a good friend that's in his 80's and doesn't have the skills/tools to do it himself. He has come up with "clever" fixes on other clocks over the last few years though, and they have run, even though I can't explain how. I have no idea how the bone became bent, it was like that when I started with it.You have a right to be nervous. See picture (red arrow) you have very little lock. Locking on the tip of the pallet. Very close to slipping and spinning free and wrecking the escape wheel. But look at the blue arrow, looks like "the bone" itself is bent from previous adjustments (rivet did not move) any further bending of the bone without the rivet slipping could cause it to snap off - yes, I would be nervous.
This is before the adjustment in post # 66
It looks like it should run "safely" and reliably. The beats seem to be consistent with the new ew, so I would say maybe pretty good, not perfect but pretty good. I think I would play with tilting it slightly left or right to see if it is possible to get a more even sound. If so, adjust the crutch slightly to improve the beat. If you move the dog bone a bit more you might get closer to perfect but you are getting close to the point where it will lock up, and then you would have to adjust pallet spacing and so on. You really should not demand perfection from this type of clock, its just a matter of how close you want to get and how much time you want to spend getting there. Your friend will never know that it isn't perfect and will be delighted that it runs and keeps time so..........You say better, does that mean it's good where it is, or do I need to go closer? Thanks.
I wasn't that concerned with the beat on the stand, I will get it better when it's in the case.
Thanks Willie. I refuse to let let an inanimate object defeat me, and I can't stand half-ass work, especially when I have the awesome guidance you guys have given me. I would have been letting all of us down by not getting it right.Well ... my hat's off to you for sticking to the job until it was done. Many people just drop out on jobs like this, or do some half-ass repair. They never get the satisfaction of a job well done. Willie X
No, the great wheel and second wheel are not part of the equation, the center wheel is. You count everything between the center wheel and the escape wheel, including the center and escape wheels. The great wheel and second wheel are part of power delivery but not part of the time keeping equation. There are several spread sheets that will calculate this for you.Ok, guys. It's going back into the case to get the beat set again, and get rated.
I'm trying to figure out the beats per hour so I can use my Timetrax 185 for rating.
The great wheel=84T
The second wheel=80T, 7PT
The third wheel=72T, 6PT
EW=40T, 7PT
BPH=(80x72x2x40) / (6x7)=460,800 / 42=10,971 BPH
Does that look correct?
Is the center wheel the wheel that the hour cannon is on?No, the great wheel and second wheel are not part of the equation, the center wheel is. You count everything between the center wheel and the escape wheel, including the center and escape wheels. The great wheel and second wheel are part of power delivery but not part of the time keeping equation. There are several spread sheets that will calculate this for you.
What software gave you that readout? Can I get that using my Timetrax 185?
Thanks Willie, that's pretty much how I've been rating clocks. It's good to know that I've been on the right track!Just hang it on th wall, without the dial but with the hands.
Set the beat/time and let er run. When you hear it strike take a glance at your phone (or atomic clock) and adjust as necessary.
Initially, I don't make an adjustment until it's two minutes out.
All clocks need to run for a couple of weeks after any repair, So, I always do the rating along with the test run. It only takes a few seconds per adjustment, much faster and more dependable than using a counter.
Note, you can expect an old spring driven clock to gain a bit when first wound, so disregard the first day or two, if it's running a little fast.
Week to week, making tiny adjustments is the only good way to fine rate a clock but this is best done at its home by its owner. Why (?) because it takes a month or more (if you do it) and when you move it, the time you spent is often wasted.
This looks like a 30-hour (1-day) movement, so it has fewer gears. There are two basic going train designs, one has the center wheel included in the power delivery train (not this one), and one the center wheel is not part of the power train but just rides along with one of the gears that is (this one is that type). Note that the GW wheel powers the 2nd wheel and the center wheel powers the 3rd wheel and the center wheel also connects with the 3rd wheel and just goes along for the ride and powers nothing except the hands. The numbers are not important, in a 1-day clock the EW is typically the 4th wheel, in an 8-day clock the EW is typically the 5th wheel.Here's a picture of the movement with the wheels I'm sure of labeled. Can someone label the last ones so I'm sure of which ones to count for the BPH? Hopefully, this will get me to the end.
If it is really annoying, you can peen or pinch around the edges of the hole to close it.I've noticed when setting the time, the minute hand is very loose on the arbor. It's like the square hole is too big, either by it being a replacement of the wrong size or just worn from so many years of use. Is there a simple way to close up that hole? I was thinking of peening around it or adding some solder to the hand and closing it up then fitting it to the arbor. Right now I can move the hand about the equivalent of two minutes without the arbor moving. Not crucial but annoying.
Peened it, filed it a bit, and now the slop is gone!!If it is really annoying, you can peen or pinch around the edges of the hole to close it.
