another use for delrinAF
bruce linde
11,120
2,734
oakland, ca.
clockhappy.com
my chelsea ships bell strike sounded mushy... and indeed the 1909 hammer tip leather was mushed out of shape.
i turned a new tip out of 1/4" round delrinAF stock.... must have taken an entire five minutes all in.
pressure screwed right in, sounds great. :)
Dave T
Dec 8, 2011
4,597
536
NC
Will, I don't know where Bruce buys it, but a quick search shows many resources. Just saw a 10 pack for $3.28 on ebay.
bruce linde
11,120
2,734
oakland, ca.
clockhappy.com
McMaster-Carr.... but it does look like there are cheaper solutions.
btw... you want delrinAF, which has some teflon in it. you can use it for bushings, pinion gears, all kinds of stuff. lathes eat it for breakfast snacks... incredibly easy and quick to work with.
i got a 2' piece at McMaster-Carr for $3... + twice that in shipping (doh!)
RJSoftware
Apr 15, 2005
8,846
283
Loxahatchee, Florida
Teflon scares me, supposedly in near everyone's bloodstream due to no stick pans. Also, I have a tendency to not wash my hands and lick my fingers and pick my nose.
Dave T
Dec 8, 2011
4,597
536
NC
Not me. I use cast iron. A good well seasoned pan won't stick. But it's also a matter of how hot you need to get it before you put anything in it.
Now we can start an iron discussion! ;)
bruce linde
11,120
2,734
oakland, ca.
clockhappy.com
btw... a delrinAF hammer tip is going to be louder and brighter than a leather tip.... just an fyi.
Bruce Alexander
Brass Member
Feb 22, 2010
7,809
987
Hanover, PA
www.testoftimeclocks.com
I've used straight Delrin for Sonora Chime hammers. The stuff machines beautifully. I've used a die to cut threads. The Delrin tips I've placed will definitely outlast me, but then, leather tips will too.
Dave Diel
Feb 28, 2014
664
55
Denver, Colorado
I found a plastics fabricator nearby that will give me scrap Delrin almost free. However, he normally deals with rods that are 1 1/2" dia, so I have a lot of material to remove to make a small part. While it cuts super easy, it's stringy and has a tendency to birds-nest around the part. After fighting this for a while I came up with using a small shop vac to suck up the long stringy chip while it is coming off the cutting tool. Makes machining Delrin a lot more pleasant.
R. Croswell
13,218
3,015
www.greenfieldclockshop.com
I use this stuff for bushings in wooden clocks and all sorts of things. Don't recall ever using for hammer tips but it should last forever. The only problem with the AF (anti friction) version is that the Teflon tends to prevent glue from sticking well. McMaster-Carr also lists it as "slippery Delrin".
About the only safety issue with Delrin is that a small amount of supposedly somewhat toxic gas is released during some machining operations. Probably insignificant when machining clock size parts but good ventilation is always nice in the shop.
Teflon in the bloodstream....... perhaps the medical industry should take a closer look; might help the blood to flow and prevent clots. As for iron cooking pans, I don't like to cook and they don't work so well in the microwave!
50,160
3,301
Cast iron pans are nice for cooking, but not nice to modern smooth top stoves. They scratch them up. Great for camping though!
Bruce Alexander
Brass Member
Feb 22, 2010
7,809
987
Hanover, PA
I think the cast irons work well with induction cooktops. One would probably need to be careful on them too since they have a smooth, "glass" top. If you're cooking over a campfire and coals, the bottom is probably going to be a little rough. :)
TEACLOCKS
Mar 22, 2005
3,355
282
73
Santa Rosa Calif.
www.weserviceallclocks.com
S_Owsley
Jan 24, 2011
384
109
69
San Francisco
I don't even know where to begin when someone is afraid to handle virgin Teflon material with their hands. Are some of you guys using whale oil as a lubricant and ivory soap as their parts cleaning solution? While I do own a non-stick pan for special purposes, one of the first things I bought when I moved out of my parent's house was a new cast-iron skillet. It's over 40 years old now and is seasoned well enough by now. Countless pans of cornbread have been baked in it.
RJSoftware
Apr 15, 2005
8,846
283
Oh my Derlin, oh my derlin, oh my Derlin Clementine.
You where gone & lost 4ever,
now I'm usin the cast iron.
and for those who didn't know the controversy Clementine.
: "Though in life I used to hug her, now she's dead—I'll draw the line."
19,651
4,691
I think there might be a law agin that. Might depend on your state though. Ha
For a hammer head, regular ole (available everywhere) Nylon 6+6 would probably function the same as Derlin.
Schatznut
Sep 26, 2020
1,602
907
SoCal
i can't quite hit the 'like' button on that last post.... :)
Yeah, a bit too much info there... If you're worried about the PTFE in Delrin, how do you deal with the fact that most brass has lead in it to increase machineability? Delrin and brass both machine beautifully and are wonderful to work with. Maybe NAWCC should hold a seminar - "Good Hygiene for the Average Clock Butcher"...
Schatznut
Sep 26, 2020
1,602
907
SoCal
Can't find DELRIN anywhere
That's funny - I did a google search just for grins and it returned over 7,000,000 hits. If that doesn't work for you, try "acetal" or "polyoxymethylene."
RJSoftware
Apr 15, 2005
8,846
283
Cut the tips of your nipples off and cover hammers to soften sound.
(baby bottle nipples, for Pete's sake...). I guess they is silicone.
Probably have a hard time turning a silicone nipple on the lathe, too gooey and bloody painful, to watch, that is. Might want to take them to a butcher he can slice the ends right off. But you have to pay him with Schatz clock. That's ok, just drive to any dump, plenty there.
RJSoftware
Apr 15, 2005
8,846
283
I wanna make a passport law, mandatory banjo playin and/or moonshine jug puffin. Yeeee haaaaaw..!
But yep, errrr hmmm, nylon is tough.
50,160
3,301
My late brother in law, a superb guitarist, used to say "I love the way an accordion sounds when it lands on a banjo in the garbage bin." I guess he was not too fond of either, even though his wife was a state champion accordion player at one time :D
Bruce Alexander
Brass Member
Feb 22, 2010
7,809
987
Hanover, PA
Delrin can be purchased from a fair number of sellers on eBay. DelrinAF has the Teflon which isn't really needed for hammer tips, but there's no reason it can't be used for that purpose, plus it makes good bushing material as attested to by RC.
Here are a couple of photos from the last time I used Delrin for hammer tips/inserts:
Schatznut
Sep 26, 2020
1,602
907
SoCal
Ummm... alrighty then. He's the late husband of the state champion accordion player. hum.
Tbucket
May 7, 2016
78
23
Easton, Pa
A good way to break up the stringy chip when turning a large amount of Delrin is to first plunge grooves in the OD. Then when turning the chip will break as your turning tool passes thru the groove.
Staff online
184,069
1,607,652
56,019
jedmas
3,195
Top Bottom
