Another strike question for my Sessions
TonyR
Mar 4, 2005
418
The wishbone clutch spring thingy that puts the count wheel under tension on a Sessions mantle clock appears to be allowing the wheel to wobble a bit to and fro. This is causing the count lever to misalign with teeth and, sometimes, to miss the deeper slots and so not stop the strike sequence.
Am I right in thinking it is the wishbone at fault? How do I fix that?
TonyR.
TonyR
Mar 4, 2005
418
TonyR.
Scottie-TX
Apr 6, 2004
936
61
80
Mesquite, TX
Well, "TR": You might be right but I don't think so. If your theory is correct then add tension to th' witchboan and that should take care of that - jes benditaliddle. I'd look elsewhere for your problem. REASON? Witchboan only allows lateral wobble while your problem doesn't seem related. Does it matter if it wobblesalittle long as countlever finds it? Nope . Your observation is worthwhile - but not the problem. Your problem is "stop the strike". Observe the hook on the stop lever as it approaches the stop pin. Slow down the action by interrupting the fly or slowing the wheel that drives it with a finger. You'll probably find the stop lever is not going deep enough into the stop pin and skipping over it.
lpbp
NAWCC Star Fellow
NAWCC Life Member
Aug 25, 2000
2,982
64
Tony, it sounds like you are right about what's going on. Just tension it by bending, you may be able to do it by not taking it apart, using a wire bender to do the job. You can make your own by cutting a slot in a broken screwdiver or just steel stock.
Larry Pearson, FNAWCC* #35863
Scottie-TX
Apr 6, 2004
936
61
80
Mesquite, TX
I'm probly wrong "LB" but I think th' wishbone he's referring to is the one that retains the countwheel to it's arbor with a little locking tab to secure it - that thin brass retainer?
Mike Phelan
Dec 17, 2003
10,134
78
West Yorkshire, England
S'what I thought, in which case, if the CW is wobbling a bit, the spring is loose and can be sorted without dismantling.
TonyR
Mar 4, 2005
418
Hi,
Thanks guys, I did a bit of fiddling and I think we're rocking and rollnig now.
Thanks again.
Scottie-TX
Apr 6, 2004
936
61
80
Mesquite, TX
HUH! TR that's great but I never new playin' a violin was therapootik fera klok. Hmmmm. Mebbe I'll start fiddlinaliddle more around my clox.
166,931
1,454,654
87,192
justincasejustintime
