Another mystery clock.
Discussion in 'Clock Repair' started by bangster, Aug 12, 2017.
  1. bangster
    bangster Super Moderator
    16,320
    21
    How the hey am I supposed to get into this danged thing to change its battery?
    The back is silicone rubber, with suction cups. Its edge is inside the turned down metal rim.
    I tried getting something inside the rim, to pry it out. had no luck.
    Tried pushing on the front side, to force it out. It flexed, but didn't budge.
    Have y'all ever seen a clock like this before?
    View attachment 353378 View attachment 353379 View attachment 353380
  2. Dick C
    Dick C Registered User
    Oct 14, 2009
    1,254
    According to answers from Amazon:
    Hold on to the silver outer ring and push down in the middle of the clock face and easy it out with steady pressure. I think there is a rubber gasket in there that holds the clock in place.... it "should" come out. I haven't had that trouble with my clock and have used it several months.
  3. bangster
    16,320
    21
    Thanks. Not quite right, but I figured it out.
    The rubber back doesn't come off. But if you press on the middle of the back, the clock pops out the front.
    I was trying to do it backwards. :(:(
  4. glenhead
    glenhead Registered User
    Nov 15, 2009
    803
    10
    Telecom Engineer
    Williamson County, Texas
    So "acetylene torch" would not have been the correct answer. Dang.
    Glen
  5. David S
    David S Registered User
    Donor NAWCC Member
    Dec 18, 2011
    5,803
    20
    Brockville, On Canada
    Or three ton arbor press.
    David
Similar Threads - Another mystery clock Forum Date
Countwheel mystery Clock Repair Oct 9, 2017
Soldering a Bezel to a Dial - Is There Another Method Clock Repair Jul 11, 2017
Morbier loose hands catching on one another Clock Repair May 16, 2017
Vise Mount Metal Brake/Bender Another Great Crossover Tool Clock Repair Jan 7, 2017
Another mainspring query Clock Repair Oct 21, 2016
