American Another model 10 Herschede
Salsagev
Feb 6, 2020
1,117
105
14
Madison
www.youtube.com
Hey everybody, I just purchased another Herschede clock because I thought it would look good in the collection. As shown in the book, it is the 2015 model with redwood panels. This model is less expensive than the other Herschede hope it wasn’t from an old tree. There are the normal cobwebs in the clock.At a first glance, I see the serial number is 55155 (I like that). Overall the case is in nice shape and all bits and pieces seem to be there. The usual “alligator” texture has taken place. 6ADA7A43-86A0-4C39-96DC-46BB7260830E.jpeg 6C31DC39-D070-41C8-86B2-2343DC3DF3E9.jpeg
At the dial, I see the two screws are completely holding the dial in, which correctly exposes the levers and arbors. The dial is interestingly marked “Rost Jewelery Co Indianapolis”. Never heard of that but it sounds intriguing. 599E4FFA-EE88-40A0-9FDD-26CE86345C03.jpeg AC8F0E41-6799-4693-BFE8-37A58A48B07E.jpeg The only problem with the dial is that it doesn't latch fully like it’s supposed to.
Next is the movement: It looks in good condition overall. The “satisfying” pattern is present. EE3D4E73-F2B3-4989-B49F-AA95EC27E2C1.jpeg 88984FC3-EF09-45B0-8F0C-445F82CA771E.jpeg F381F2BE-3477-4B9A-9ABA-018F4425F7E4.jpeg All parts seem to work and the stop works are nice. The movement is relatively clean but still needs a service which will be a (future) project. The pendulum is in great condition. The key has been lost by the seller but will come back to me if found.
One thing I noticed is how the dial mounts the “poles”. This seems to allow the poles to be screwed in and be adjusted. This is different from the other model ten where it was soldered on. Perhaps it was “tampered” with since the past owners said they “tinkered” around with it. 7AA86239-351F-45B9-8D5F-BB3F8CC4738E.jpeg E224FF92-7561-4BFC-A9AD-EEC328B98D70.jpeg
Any comment or thoughts are appreciated! Thanks!
E22EF2E6-F2C2-4173-BA7F-4FDA3E9C9AF0.jpeg DFE00292-D86D-446D-9B8A-6A34B953677D.jpeg DF4E1E2D-4E1F-4DBF-9C9B-AC8CF8045DBD.jpeg 56DFBDCA-2348-4B38-9370-ABB56A41E42E.jpeg A669D713-DAFD-4314-B327-D690DEF48827.jpeg 2ECC0559-CE9E-4C9E-A4DC-C524A24CE52B.jpeg Link to the other Herschede:https://mb.nawcc.org/threads/herschede-clock.172368/
Reactions: chimeclockfan
chimeclockfan
Dec 21, 2006
4,463
378
WI
Looks great in the photos. I find the dial bezel shafts were sometimes soldered in place so they would keep firm instead of slipping out. I've had to reinforce shafts that wouldn't hold in the bezel before. Any videos of the chimes?
Reactions: Salsagev
Isaac
Aug 5, 2013
1,052
241
Nice clock! Model 10's were always robust.
Excited to hear the video of it chiming!
Reactions: Salsagev
new2clocks
Apr 25, 2005
3,190
480
Pennsylvania
Hey everybody, I just purchased another Herschede clock because I thought it would look good in the collection. As shown in the book, it is the 2015 model with redwood panels. This model is less expensive than the other Herschede hope it wasn’t from an old tree. There are the normal cobwebs in the clock.At a first glance, I see the serial number is 55155 (I like that). Overall the case is in nice shape and all bits and pieces seem to be there. The usual “alligator” texture has taken place. View attachment 630632 View attachment 630636
At the dial, I see the two screws are completely holding the dial in, which correctly exposes the levers and arbors. The dial is interestingly marked “Rost Jewelery Co Indianapolis”. Never heard of that but it sounds intriguing. View attachment 630631 View attachment 630633 The only problem with the dial is that it doesn't latch fully like it’s supposed to.
Next is the movement: It looks in good condition overall. The “satisfying” pattern is present. View attachment 630630 View attachment 630640 View attachment 630638 All parts seem to work and the stop works are nice. The movement is relatively clean but still needs a service which will be a (future) project. The pendulum is in great condition. The key has been lost by the seller but will come back to me if found.
One thing I noticed is how the dial mounts the “poles”. This seems to allow the poles to be screwed in and be adjusted. This is different from the other model ten where it was soldered on. Perhaps it was “tampered” with since the past owners said they “tinkered” around with it. View attachment 630642 View attachment 630641
View attachment 630628 View attachment 630629 View attachment 630634 View attachment 630635 View attachment 630637 View attachment 630639 Link to the other Herschede:https://mb.nawcc.org/threads/herschede-clock.172368/
Here is a thread on the Rost Jewelry Company of Indianapolis:
Rost Jewelry Co, Indianapolis, IN. Established 1886 | NAWCC Forums
You made a nice acquisition.
Regards.
Salsagev
Feb 6, 2020
1,117
105
14
Madison
www.youtube.com
Salsagev
Feb 6, 2020
1,117
105
14
Madison
www.youtube.com
I just discovered the first and bad flaw. The time spring ratchet has a hairline crack right down the middle so it has no more tension. It seems the whole Stop work assembly let go and the spring slips when wound.
Isaac
Aug 5, 2013
1,052
241
That's a bummer, but it is fixable. Is there any damage up the time train from the spring letting go?
Salsagev
Feb 6, 2020
1,117
105
14
Madison
www.youtube.com
I’m not sure how to examine the stop works. Do they let go along with the mainspring?
164,686
1,432,664
85,738
cspeed8
2,863
