I found this stuff at the local Ace Hardware. It does a bang-up job on brass clock plates, and it's quick. Rub it on, rub it around a bit, rub it off. Presto!
bangster
bangster
Ammonia + chlorine bleach = phosgene gas...one of the chem warfare faves in WW One. Kills indiscriminately and unpleasantly.Len said:Paul
Be careful what you mix with ammonia. The wrong mix can be deadly!
That's interesting....Mike Phelan, who used to post here, insisted that the "old English" way to clean clocks was with Brasso, and to polish out with chalk thoroughly.Bob said:Could this be anything like Brasso? The fellas in Australia absolutely insist that we never-never use Brasso on clock plates. I appears it amalgamates into the pores of the brass and becoms a wonderful rubbing/grinding compound. Comments?
I meant to add "in the pivot holes".
Hey hey, Arjay. Haven't seen you in a while. Good to see you back.RJSoftware said:Oxilate is a chemical found in tea. Maybe a relative. It is one of the key ingrediants in the formation of kidney stones. Why I also don't drink tea anymore.
