This sounds daft, and I am somewhat embarrassed to ask, but...I have this relatively modern Hermle movement inside a large and very heavy brass case mantle clock. The problem is how to get it out: several screws detach movement from front of case, but it can't be moved forwards or backwards too far because of the dial plate attached to front of movement and the movement itself, just too wide to be pulled out through front of clock case. The dial is held in place by three pins or should be: There are only two and one of which I managed to remove. But the other, being a very short pin and very difficult to access, is a nightmare to get out. See attached pix.
Any ideas on how to tackle this?
TonyR.
TonyR.
