You could be right, I will try again but why use a square pin?It's been a while since I worked on one of these, but I thought it was the spring tention that held that pin in place. Can you not depress the spring and pull the pin out?
The square pin is not threaded and by compressing the leaf spring I have moved it into the centre post off the right top of the spring.You could be right, I will try again but why use a square pin?
Its really hard to pull out, I had to use a tiny drift and matching hammer to move it that far. Why use a square pin, I think its to push the pin in with a flat side down, then rotate it onto its edge to apply more pressure, and hold it in place.
I missed the boat here initially and will make a tiny spanner to fit across the flats and hopefully rotate it? The hole is round.
IS THERE A COMPRESSION TOOL FOR THESE SPRINGS?
The bellows are sealed and move the needle on compression but the chain links have some rust spots as the spring does. It needs to be stripped cleaned and oiled, then regulated. It was never working accurately.Is it working? If so, it would be a good idea to leave it as is.Willie X
