anchor escapement problem: pallet/escapement wheel, tip-to-tip when weight 'bottomed"
Discussion in 'Wood Movement Clocks' started by Changing Times, May 13, 2017.
  1. Changing Times
    Changing Times Registered User
    Mar 19, 2015
    I need help with my design... As noted in the snapshot, when the weight reaches its final resting place, (and thus is no longer transmitting power to the gear-train), the pallet, and escape-wheel invariably stop tip-to-tip. I've tried adjusting the angle of the impulse face, and adjusting the depth of the pallet's entry into the escapement-wheel. The clock runs fine. My concern is: when the clock stops, the inertia from the swinging pallet has the potential of moving the anchor out of position. What am I missing? 304803.jpg
  2. Changing Times
    Mar 19, 2015
    ... correction: the sentence above should read, "the inertia from the swinging pendulum, (not swinging pallet)...
  3. Burkhard Rasch
    Jun 1, 2007
    4,703
    105
    General-and trauma surgeon
    Twistringen
    Re: anchor escapement problem: pallet/escapement wheel, tip-to-tip when weight 'botto
    this is why e.g turret clocks have a device that disconnects the pendulum from the anchor in that said condition so that the anchor pallet is not driven into the flancs of an e.w.tooth and destroying it.Think of a crutch that lets free the ancor pin when there is no power on the train and the e.w. is not moving foreward.
    Burkhard
  4. Changing Times
    Mar 19, 2015
    Thank you Burkhard. I'm glad to know there are solutions to my dilemma. To borrow from Persius, I'm now trying to create something from nothing... Can you direct me to a drawing of such a device? Again, many thanks for your reply!
  5. Tinker Dwight
    Tinker Dwight Registered User
    13,666
    You might try a simple thing. A ball bearing in a hole held with
    a light spring. Something like use on a socket to hold it onto the
    socket wrench.
    You adjust the spring so it is tight enough to not slip when
    running but a sudden stop it pops out.
  6. Burkhard Rasch
    Jun 1, 2007
    4,703
    105
    Twistringen
    here are pics of the "letting free crutch" of my tower clock,made by E.Korffhage & Sons.HTH
    Burkhard
    PS pics changed order and direction by themselves,sorry!
  7. Tinker Dwight
    13,666
    Similar to my spring and ball except I was thinking more at the anchors
    arbor.
    I can see how the end of the crutch might be a better idea.
    You'd want to play with the depth of the V and the amount of weight
    so that it says put during normal operation. The pivot being just a little
    loose is not a big deal as most crutches have a little play anyway.
    If the weight stopped before the cable did, you can put a screw
    or something on the weight so it tilts sideways. This will bring thinds
    to a gradual stop.
  8. Changing Times
    Mar 19, 2015
    Those are great pics, Burkhard! Thank you very much. I have one question regarding them. From what I can tell from the angle of the photos, there is 'nothing' behind the pendulum in the way of mechanism. Is that correct? Again, thank you very much for your help.
  9. Changing Times
    Mar 19, 2015
    Thanks Tinker Dwight. I'm having difficulty visualizing what you mean by: 'putting a screw
    or something on the weight so it tilts sideways.' It seems to me that whatever method is used, the tension in the cable/chain, will equalize at a given rate...
  10. Burkhard Rasch
    Jun 1, 2007
    4,703
    105
    Twistringen
    You´re right,the movement is sitting on its support construction and the pendulum-suspended with a double suspension spring swings behind the movement and 2-3cm distance from the wall.There is no other "mechanism" besides the horizontal pin on which the swivel lever of the crutch is resting.
    Burkhard
  11. Tinker Dwight
    13,666
    This wasn't too clear. The idea is that as the weight hits a surface and the bottom of the weight is
    flat, the weight stops more abruptly. If there is something on the bottom of the weight that
    makes it fall sideways, the tension on the cable is less abrupt as it hit the surface. This allows
    the tension to gradually reduce, giving more time for the pendulum to decay its swing and
    not come to an abrupt stop by jamming against the escapement wheel.
    It still reaches a point that it needs to slide on the back side of the tooth. The clutch
    like Burkhard shows it most likely the best method.
  12. Changing Times
    Mar 19, 2015
    Burkhard Rasch, I have been remiss, in not thanking you for your help... I've attached a snapshot showing what I was able to design, based on your photos. Thank you so much. As with all things, I may find myself modifying some aspects of the design, but it seems to work adequately, thanks to your help! Thanks again!
  13. Burkhard Rasch
    Jun 1, 2007
    4,703
    105
    Twistringen
    that should work!Congrats!:clap:
    Burkhard
  14. Russell Dickson
    Russell Dickson Registered User
    Dec 1, 2011
    955
    73
    Freelance Writer
    New York
    Wow Burkhard I didn't know you have a tower clock. That is cool. You have anymore pics or info on it. Not to highjack this thread or anything
  15. Burkhard Rasch
    Jun 1, 2007
    4,703
    105
    Twistringen
