An Unusual Waltham Riverside?
Bildeborg
May 15, 2018
245
35
60
Cornwall, England.
Having not curated my pocket watch collection in a while I decided to pull them out on Christmas day to take a peek.
One that had me puzzled when I bought it and still puzzles me now is a Waltham model 1892 Riverside from 1899. It is in an open face case but with the seconds bit at 3 o'clock. It has 17 jewels and is lever set. The seller told me it was a rare grade 45 non magnetic piece.
Serial number is 7013760 which I believe is from a batch that appears to be missing from the Waltham lists. I'm not able to post a picture at the moment but any info on this unusual watch would be very welcome.
Jay.
Jerry Treiman
Golden Circle
Aug 25, 2000
7,317
5,063
Los Angeles, CA
First, I am assuming that your movement is marked "NON-MAGNETIC" and not Riverside. If so, yes, it is one of the relatively uncommon grade 45 movements, and it is from the first run. My research found there were 280 made for open-face casing and 300 for hunting cases. This is a special model in that it was made specifically as a non-magnetic watch. If your dial is enamel it may be what many consider a desirable factory conversion dial used to case a hunting movement in an open-face case.
Reactions: 179
topspin
Dec 14, 2014
1,702
581
With only the serial number to go on, there's at least 4 sources of information...
...from which I conclude that the records do not have a "single version of the truth".
If it were mine, then I would be content to say that if it's got Riverside stamped on it then it is a Riverside, otherwise grade 45 is as good a guess as any and we'd really love to see some pictures.
Grade 45 is not "rare" in the sense we use it here (580 pieces in total from 9 runs) but well deserving of "unusual".
Bildeborg
May 15, 2018
245
35
60
Cornwall, England.
Somewhat late I know but here are some pictures.
As can be seen, my regulator differs slightly from Jerry's above inasmuch as the 'star' is totally different. Also, mine states "17 Jewels" before the word "Adjusted". The placement of the seconds bit at 3 o'clock is a bit unusual I think.
Jay.
Edit: I now realise I was incorrect to say it was a Riverside model.
topspin
Dec 14, 2014
1,702
581
Re: The position of the seconds bit - this is a hunter movement (designed for use in a hunter case) wearing a conversion dial. A little unusual, but not at all rare.
Looking at the photo I don't see any extra screw marks, therefore this is likely to be an all-original combination and should definitely be kept together. Nice.
Bildeborg
May 15, 2018
245
35
60
Cornwall, England.
Topspin, I have read elsewhere & have been told that the dial is indeed quite a rarity. I certainly have never seen another as mine.
As a whole, with only 300 of the watches ever produced (in this format) and very few of those fitted with a factory conversion dial, I should imagine taken as a whole it is quite a rare piece.
Regards the movement & case, I cannot think why I would ever separate the two so no worries in that regard ;-)
Jay.
Reactions: musicguy
Bildeborg
May 15, 2018
245
35
60
Cornwall, England.
Here is why I initially thought it a Riverside model......
Grade: Riverside
Manufacturer:
Waltham
Manufacturer Location:
Waltham, Massachusetts
Movement Serial Number:
7013760
Grade:
Riverside
Model:
1892
Estimated Production Year:
1897
Run Quantity:
900
Total Production:
5,200
Size:
18s
Jewels:
17j
Movement Configuration:
Hunting
Movement Finish:
Nickel
Movement Setting:
Lever
Plate:
Full Plate
Regulator:
Patent
Hairspring:
Breguet
Adjusted:
Yes
Adjusted to Position:
Yes
Data Research:
1954 Waltham "Gray Book" List
Research Note: Waltham Serial Ledgers originally designated serials 7,009,001-7,701,700 as Grade K. However, the Waltham Gray Book serial list and various observations provide evidence that multiple runs exist within this original range, including Vanguard, Crescent Street, and Riverside (18s/M1892 and 16s/M1888).
.....so clearly an error on the serial numbers website, thankfully now corrected.
Jay.
Rhett Lucke
Board Chair
Director
Feb 18, 2001
2,221
1,440
rrstd.com
Jay.
Here’s another example with the same regulator and similar conversion dial.
3D327A31-3EAA-474D-B7E6-6ECB7D5A762F.jpeg ED5F5C3D-E6C2-4EB8-A74C-A7228B337A3D.jpeg
Bildeborg
May 15, 2018
245
35
60
Cornwall, England.
Nice one Rhett. Interesting to note yours also has '17 Jewels' printed before the word 'adjusted'.
whereas Jerry's does not.
Jay.
Jerry Treiman
Golden Circle
Aug 25, 2000
7,317
5,063
Los Angeles, CA
Since the 300 movements that include my movement (post #4), Bildeborg's (post #6) and Rhett's (post #10) were finished over a four year period (and not necessarily in sequence) it is likely the few finish differences that we see are the result of changing production and finish specifications over that time period.
Jerry Treiman
Golden Circle
Aug 25, 2000
7,317
5,063
Los Angeles, CA
[ . . . ] http://nawccinfo.nawcc.org/LookupSN.php?serial=7013760&sernumin=
I was the person who transcribed that portion of the ledger for our database. The report is correct but the scanned ledger page ...
(and condensed version in the gray book) are lacking detail that was available on an additional un-numbered ledger page that was not reproduced for the on-line database
Old rookie
Feb 6, 2021
389
1,019
93
84
dublin, ca
Thank you, Jerry for your ongoing contributions to the NAWCC! :clap: :clap::thumb:
Similar threads
R
Replies
Views
1K
R
C
Replies
14
Views
2K
Steve Maddox
S
177,715
1,557,625
53,661
sara.fagan73
909
3,061
