An unusual case
Discussion in 'European & Other Pocket Watches' started by Dr. Jon, May 30, 2017.
  1. Dr. Jon
    Dr. Jon Registered User
    Dec 14, 2001
    5,001
    12
    Aerospace Engineer
    New Hampshire
    I recently acquired this watch in an open face 18K case.
    [​IMG]
    It looks to be fairly standard English 'crystal" open face case but it is hallmarked for Edinburgh 1943.
    The movement is by Louis Audemars and is an independent seconds movement. I believe I got it at a fairly low priced because it was regarded as a re-case.
    I suspect that it may not have been cased at all until this case was made in 1943 but the case is not marked at completely as I would have expected.
    The back cover has the full hallmark set as shown
    [​IMG]
    Here is a closer view of the marks
    [​IMG]
    The inner cuvette is not fullv marked
    [​IMG]
    The bow is marked as shown
    [​IMG]
    The case itself has a serial number very different from the movement number which is 9384. The seller date the movement manufacture to 1864.
    I suspect that either teh case was purpose made for the movement or that the backs were replacement for those on an the original case body which may have been made in Switzerland, to english style.
    There are some minor dial repairs which may be the result of being kept as an uncased movement for a long time.
    It is also possible that it just was not fully marked as there was a War going on in 1943. The 1943 mark seems unmistakable.
    Also any leads on the casemaker "CN"?
  2. John Matthews
    John Matthews Registered User
    Sep 22, 2015
    410
    Retired Systems Architect
    France
    #2 John Matthews, May 30, 2017
    Dr Jon I don't think it is an Edinburgh assay mark - it's an acorn not a thistle. I believe the acorn was used after 1907 on imported items that were assayed in Chester. On that basis this would date the case to 1913 and the makers mark would be Charles Nicholet a watch importer based at 13 Charterhouse Street, Holborn Circus, London. The mark registered 13/12/1906.
    John
  3. gmorse
    gmorse Registered User
    7,202
    22
    Retired from Xerox
    Hi Dr. John,
    John is right, this is a Chester import mark from 1913, and Charles Nicholet (or Nicolet), was the owner of Stauffer Son & Co. in London from 1879.
  4. Dr. Jon
    Dec 14, 2001
    5,001
    12
    Aerospace Engineer
    New Hampshire
    Thanks, that makes a lot more sense than Edinburgh 1943.
  5. Audemars
    Audemars Registered User
    Donor Sponsor NAWCC Member
    Aug 6, 2010
    821
    Somerset, UK
    I think this may be a similar situation to my own LA watch - a movement which had been stripped from its original case in the "great meltdown" and was then re-cased later by someone who appreciated the importance of the movement.
    To my - admittedly completely unqualified - mind there is little doubt that the "internal" clicks on the winding train indicate this is an LA movement.
    P
    www.audemars.co.uk
  6. Dr. Jon
    Dec 14, 2001
    5,001
    12
    Aerospace Engineer
    New Hampshire
    The movement is signed "L. Audemars". It also has their signature bar over the second motion wheel and the shepherd's crook lever affix.
    It is possible it was not previously cased. The independent seconds is more complex and much less useful than the Nichol's start, stop, and reset chronograph which came at about the time this movement was made.
  7. Audemars
    Aug 6, 2010
    821
    Somerset, UK
    Are we sure about the spelling of Nichole / Nicholet? There is a possiblity it may be Charles ("Charly") Nicole who was operating in London at the time and had a very close cooperation with the Audemars (in fact he married Suzanne, sister of Louis Audemars-Valette and was therefore, by marriage, my great-great uncle....).
    I have just sent a PM to Jon about the movement serial number which appears in the archive, but sadly the entry does not refer to this movement but to a cheap watch sourced by the Audemars' London depot from Matthey-Doret. An unfortunate coincidence.
    There is however no doubt in my mind about the authenticity of Jon's movement.
    P
    www.audemars.co.uk
  8. Dr. Jon
    Dec 14, 2001
    5,001
    12
    Aerospace Engineer
    New Hampshire
    Thanks for the replies. The Charles Nicolet firm is pretty well documented at this link http://www.vintagewatchstraps.com/stauffer.php They are certainly the people who imported the case in 1916 but this movement may not have been in it then.
    My watchmaking mentor looked at it and pointed out to me that the case was made for another watch and has the dreaded extra screw marks.(These are on the back ring while the movement now in teh case has its screws on teh front ring of the case) It also does not match the dimensions of the outer plate circle and has a notch not part of the fit of this movement to the case.
    It is very well executed change.
    This raises the question of whether Nicolet had anything to do with this watch.
    It remains a possibility if the refit was done in Switzerland and the import marks were placed there when the recased watch was returned to if it had not been so marked before. The practice of assaying foreign precious metal was stopped for a period ending in 1907 due to massive bad practice and this case may have been imported with a different movement before 1907 and not marked.
    The change could have been recent too.
  9. tomczc
    tomczc Registered User
    May 13, 2016
    34
    Very high grade independent jump central second pocket watch, might from La
Similar Threads - unusual case Forum Date
Late 19thC? Unusual bridge on cylinder movement. European & Other Pocket Watches Aug 31, 2017
Unusual Steel Pillar Plate European & Other Pocket Watches Mar 18, 2017
Fabulous silver repousse case with unusual design on this 1793 English verge European & Other Pocket Watches Sep 28, 2013
Need info about this unusual 18th century watch with wood and ivory case European & Other Pocket Watches Aug 9, 2013
Upside Down Pocket Watch hidden in a Hand made Kitch Art Deco Mantel Case - Unusual European & Other Pocket Watches Jul 3, 2013
