An unmarked English fusee
Discussion in 'European & Other Pocket Watches' started by TJ Cornish, Jul 8, 2017.
  1. TJ Cornish
    TJ Cornish Registered User
    Sep 12, 2013
    134
    St. Paul, MN
    #1 TJ Cornish, Jul 8, 2017
    This weekend turned into a bit of a buying trip, and capping off several American watches, I picked up this unmarked English fusee. Sterling silver, keywind. There is an onion paper from Hector Struthers of Glasgow, but other than that I can't find any other markings. Anyone know more about this?
    Thanks!
  2. Les harland
    Les harland Registered User
    Apr 10, 2008
    786
    Hertfordshire England
    Picture No4 shows what appear to be Hallmarks on the inside of the case
    If so it will be possible to date it
    There may also be case makers marks, there, which some one will be able to identify
  3. gmorse
    gmorse Registered User
    7,303
    26
    Retired from Xerox
    Hi TJ,
    From what I can make out of the hallmarks, (difficult to see clearly in the oblique angle of the picture), the date letter is for London, 1868, which coincides with the style of the movement and especially the dial. A clearer picture of the hallmarks should reveal the case maker, but very many watch movements are unsigned like this, and even when they are, the name is that of the retailer. Many watches at this period were made in Coventry as frames, even if they were subsequently finished in London, but this could equally as well have been completed in Coventry.
    It's an English lever with maintaining power on the fusee, as is usually found on watches of this type, and jewelled to the third wheel. By this time cut compensated balances were becoming commoner but were by no means universally fitted.
    Almost everything seems to be in good condition, although the hour and seconds hands aren't original, and there's some wear to the inked seconds numerals.
  4. TJ Cornish
    Sep 12, 2013
    134
    St. Paul, MN
    Thanks for the replies - here's a better shot of the case back.
    Would this have been a high grade watch? "Jeweled to the 3rd wheel" - does that mean 7 jewels?
    I know almost nothing about English watches, but with my name being "Cornish", I probably should learn some more.
    Thanks!
  5. gmorse
    7,303
    26
    Retired from Xerox
    Hi TJ,
    The date letter is a "p" and not an "n" as I first guessed, so the year is 1870. The case maker is William Carter at 7 President Street, Goswell, London. The train is jewelled from the escape wheel up to the third wheel, with the 5 on the balance and 2 pallets, (but none on the lever pivots), which should mean that there are 13 jewels in all, so a reasonably good quality watch.
  6. TJ Cornish
    Sep 12, 2013
    134
    St. Paul, MN
    Thanks so much! Is there a public source for the information you provided?
  7. novicetimekeeper
    Jul 26, 2015
    5,012
    Dorset
    It's easier with a decent book but there are plenty of lists of hallmarks online. google British silver hallmarks.
  8. Les harland
    Apr 10, 2008
    786
  9. gmorse
    7,303
    26
    Retired from Xerox
    Hi TJ,
    For hallmarks I use "Bradbury's Book of Hallmarks" which is a handy little pocket-sized book, available from the Sheffield Assay Office. For case makers, the standard book is "Watch Case Makers of England 1720-1920" by Philip T. Priestley. This is NAWCC Bulletin Supplement 20, and although it's no longer in print there are often used copies available online. Have a look at bookfinder.com.
    For the design and construction of English pocket watches, (and indeed any mechanical watches), "Watchmaking" by George Daniels is the bible, not forgetting the years of looking at them and repairing them!
  10. novicetimekeeper
    Jul 26, 2015
    5,012
    Dorset
    More valuable than any book
Similar Threads - unmarked English fusee Forum Date
A Proper “English Railway Timekeeper”. European & Other Pocket Watches Sunday at 9:44 AM
Unmarked Fusee with some sort of Auxiliary on the Balance? European & Other Pocket Watches Apr 19, 2017
Unmarked pocket watch European & Other Pocket Watches Jan 9, 2017
please help identify this unmarked pocket watch European & Other Pocket Watches Oct 31, 2016
Unmarked pocket watch European & Other Pocket Watches Jun 17, 2016
