Before 1600 1601 - 1700 German An old German thingy signed RL
DeanT
Mar 22, 2009
1,971
943
Australia
TOWER-SHAPED TABLE CLOCK (TURMCHENUHR), UNIDENTIFIED MARK 'RL' ON EACH SIDE OF A FOLIOT, SOUTH GERMANY, CIRCA 1600, striking as hours
and quarters pass, alarm clock, age and phase of the Moon , and day of the week.
Main dial with three recesses presenting the minutes in Arabic numerals numbered in groups of five, with the quarter hours indicated by Roman numerals in the center of the numbers 15, 30, 45, 60, (eg. 4III5), the hours in Roman numerals , the half-hours marked by an asterisk, the two scales surrounding a disc for the phases of the Moon in the center revolving below a plate, originally silvered, bearing a scale for the age of the Moon and partly openworked to let the phase appear, iron hands, originally gilded, cut and engraved; lower dial (originally silvered), for days of the week named in Latin, each with the symbol of its tutelary god; the back bears two small dials for the alarm clock (on the left) and the quarter hours (on the right).
Movement in iron and brass with pillars and plates, three barrels including that for the rocket motor body, horizontal verge escapement with short simple balance wheel (rear), strike on two gongs.
Prismatic case mounted on a base (associated) with a molding return engraved with streamers, without feet, the main case gilded and engraved on the front and back with a fine decoration of foliage on a streaked background around the dials, the back with a similar decoration above the dials but above decorated with St Jerome under study accompanied by his lion; the panels on each side are decorated with figures of warriors dressed in ancient times, the one on the left holding a large cross-shaped sword, the one on the right a scimitar, perhaps alluding to the endless wars between the Roman Empire and the Ottoman Empire. A scourging scene is below the 'Christian' warrior, and a sleeping king, but holding an arrow, below the 'Turkish' warrior. The tower is surmounted by
(Important wear, reassembly and changes; gaps in the arches and deformation of their top, gilding and silvering largely missing)
An engraved, gilt brass, table tower clock marked with the unidentified monogram 'RL', South Germany, circa 1600
33 x 14, 60 x 15 CM - 13 x 5.7 x 5.9 IN.
image00001.jpeg image00002.jpeg image00003.jpeg image00004.jpeg image00005.jpeg image00006.jpeg image00007.jpeg image00008.jpeg image00009.jpeg image00010.jpeg image00011.jpeg image00012.jpeg image00013.jpeg image00014.jpeg image00015.jpeg image00016.jpeg image00017.jpeg image00018.jpeg image00019.jpeg image00020.jpeg image00021.jpeg image00022.jpeg image00023.jpeg image00024.jpeg image00025.jpeg image00026.jpeg image00027.jpeg image00028.jpeg image00029.jpeg image00030.jpeg image00031.jpeg image00032.jpeg image00034.jpeg
zedric
Aug 8, 2012
2,308
648
Another stunning clock
daveR
Sep 10, 2008
444
41
melbourne, Australia
Another amazing clock with a lot of serious histo it could tell us.in addition to what it already says through its decoration.
Will you flatten the top late that is flared up or leave as is..?
David
DeanT
Mar 22, 2009
1,971
943
Australia
David
Hi David,
Will repair as much of the damage as possible in the upper canopy. Hopefully, it will repair okay and barely be noticeable after restoration.
DeanT
Mar 22, 2009
1,971
943
Australia
I haven't worked out much of the engraving or the original artist as yet but the engraving on the back is St Jerome with a lion that is probably based of Albrecht Durer's original of St Jerome in the study from early 16thC. Apologies as the photo isn't great but the lion is on the left and Jerome on the right sitting at a table.
DeanT
Mar 22, 2009
1,971
943
Australia
Bit of cosmetic surgery to the left corner of the top plate. It's pretty close to straight now and probably straighter than the other corners as the plate isn't completely flat. It's horribly dirty and some alterations to the movement but its not as easy to tell what alterations have been performed as the wheels were originally brass. Been converted to pendulum twice (front and back).
348663685_2089564051395598_8123231646137828278_n.jpg 348727225_2089564304728906_6271550684791417328_n.jpg 348730075_2089564291395574_2320626902747727836_n.jpg 349821372_2089564241395579_2816060734798577549_n.jpg 350520603_2089564021395601_6476077817221926258_n.jpg 350538296_2089564181395585_8829941669246187361_n.jpg 352096443_2089564068062263_4363156755139535914_n (1).jpg 352096443_2089564068062263_4363156755139535914_n.jpg 352369584_2089564211395582_1032708548643520359_n.jpg 352394062_2089564168062253_8210907285549853435_n.jpg 353452442_2089564261395577_2785031160000323002_n.jpg 353454277_2089564128062257_656636919698278966_n.jpg 355136895_2089564098062260_5270038073511542421_n.jpg 355158067_2089563991395604_7925933624877062856_n.jpg 355894454_2089564001395603_4453984846050428627_n.jpg 355896717_2089564144728922_2172436150668446571_n.jpg 356240699_2089564271395576_3127981301855805913_n.jpg 357081321_2089564248062245_2061291035502956250_n.jpg 357128286_2089564034728933_4238981089399055756_n.jpg
WIngraham
Apr 19, 2019
379
257
36
Spectacular, thanks for sharing such clear pics. It is a rare view.
P.Hageman
Jul 20, 2014
1,303
408
The Netherlands
Wonderful and amazing! What else can you say, thanks for sharing these pictures of such a rare special clock!!
183,987
1,606,997
55,985
Adalbert
3,195
Top Bottom
