An interesting and useful Hand puller (Review)
DeweyC
Feb 5, 2007
2,633
1,193
Baltimore
www.historictimekeepers.com
I bought this Chinese needle hand puller on ebay. It is nicely finished and comes with 3 sizes of pullers and "needles" for putting the force on the hand arbor.
The needle is advanced via a screw and gradually lifts the hand. It is good enough for aircraft clock hands as shown, so it will work on watches.
This system means a dial protector is truly a backup as nothing touches the dial. It also avoids pulling the hand off the pipe (very annoying).
Some of the pullers are not aligned to the center correctly, but this can be corrected by removing the very thin bridge between the two jaws. I don't think it provides all that much structure.
This is much better than the Presto puller, D tweezers, or levers (my standard). I was hoping to use it to remove chrono drive wheels but I have not figured out how to adapt it.
praezis
Feb 11, 2008
545
58
Germany
Thank you for the hint.
How thick are those slotted plates - are they rigid enough to pull stubborn PW rollers?
Frank
DeweyC
Feb 5, 2007
2,633
1,193
Baltimore
Frank
Frank,
It may just. You might have to turn up new needles though. Plate thickness is about 30/100mm.
I know I am not suggesting anything new to you, but what about holding the roller in a collet and turning the balance by straddling the arms with a tweezer?
DeweyC
Feb 5, 2007
2,633
1,193
Baltimore
How exactly does it avoid this? It is still "pulling" on the underside of the flat portion of the hand, correct?
Cheers, Al
Al,
There are three sized slots. They lift by pulling on the underside of the shoulder of the pipe. If the hand is frictioned to the pipe (many modern ww's) then ti may well take the hand off the pipe. And I agree that is very annoying.
praezis
Feb 11, 2008
545
58
Germany
Thank you for that info.
I fear that would be a competition: what is tighter, roller or rivet? But I use this method regularly to pull the finger from chronograph runners.
Probably Chris showed the tool. But I never saw this in Europe.
Frank
171,041
1,493,339
50,086
Johnfn70
2,967
