An Anglo-American wall clock
Jerome collector
Sep 4, 2005
969
159
Omaha, NE
This clock represents a bit of a deviation from my normal collecting interests, although it does have some connection to Chauncey Jerome (even if it's a bit of a stretch). This is a style of clock known as "Anglo-American", due to its American movement and English-made case. Anglo-Americans, as a class, are visually stunning, with beautiful veneers and ornamentation. This one, however, occupies the plainer end of the spectrum, having no "bells and whistles." At one time, it had the typical "ears" attached to the side of the case. Those are long gone. Normally, Anglo-Americans have horizontal turned elements (like scrolls) that extend below the clock (see this posting for an example). Mine terminates in a flat bottom, which I believe is original, because it's veneered. Without the distractions of the normal flourishes, its simplicity allows you to instead appreciate the graining in the veneer.
The 8-day movement with no maker's stamp is typical of late Jerome or early New Haven Clock Co. movements. The primary feature that distinguishes a Jerome or an early New Haven movement from a later New Haven movement is the shape of the escape wheel bridge, which is necked in earlier versions and tapered in later ones. The tapered escape wheel bridge was introduced sometime in the 1870s. Just to be clear, by Jerome I'm referring to Chauncey Jerome (or the Jerome Manufacturing Co.) and not "Jerome & Co." Many Anglo-Americans have labels identifying "Jerome & Co." as the maker, but these post-date the bankruptcy of the Jerome Manufacturing Co. in 1856. I don't know when Anglo-Americans were first introduced, but I'm inclined to think this movement is a post-1856 New Haven rather than a Jerome. I'd love to get my hands on a copy of Doloff's Evolution of the Anglo-American Clock to flesh out my knowledge of these clocks.
The case construction is on the crude side. In the front view showing the rectangular box, notice the uneven cut across the front. From the side view close-up of the door, it appears that the opening for the door was cut out by first drilling two holes (roughly 3/8"), which perhaps allowed inserting a saw blade to make the cuts. Notice on the hinged side of the door that the corners are nicked off. Those corners were originally mated with the drilled holes in the case. The rectangular door was simply turned 180 degrees so that the holes no longer line up. Whatever kind of saw was used, the blade cut a wide swath, because the gaps are pronounced around the edges. Although not visible in any of the photos, the opening to view the pendulum was also crudely hacked out. The applied garland surround hides the rough nature of the hole.
The upper glass is a wonderful piece of old glass that I believe is original. The dial has been amateurishly touched up. Interestingly enough, even in areas where I'm not convinced there were touch-ups, the numerals are not very refined (a feature I've seen on other round dial Anglo-Americans). The hands are likely original, or at a minimum are appropriate for an Anglo-American. The hinges may not be original, as there's a rectangular shadow peeking out from under the upper one. There is no label, nor does it appear there ever was one. The back of the clock has some pencil notations that may represent a repair or a sales date (likely a re-sale, not original sale).
All in all, a piece that nicely sets off the veneer, but I'm hard-pressed to believe this was the product of a case-making factory. It seems too raw in its construction details. However, I suppose an argument could be made that since most of the crudeness is hidden, the lack of refinement may have been an intentional, cost-saving strategy. Perhaps someone with a copy of Doloff can let me know whether these were the product of small, low volume shops or high volume factories (or both).
[And, yes, that is 70s era shag carpeting. Fortunately, the only room its in is my office. The rest of the house (built in 1924) has beautiful oak floors. I'm sure the office does, as well, but we've never attempted to pull up the shag. Let sleeping dogs lie; even "shaggy" ones!]
Mike
Steven Thornberry
User Administrator
Jan 15, 2004
25,693
2,695
Here and there
The case of the curious case. Doloff does not show one like it. Although he does show flat-bottomed cases, he describes them as "for shelf or pedimental mounting," and the pictures of such clocks bear him out (although some of them may be wall clocks, for all I know - he does not go into details about them individually). Nor did I find any comments by him bearing on the quality of case construction or the volume of production. Doloff's greatest value, IMO, is as a picture book describing, more or less generally, what he has gleaned from the clocks he has seen or had described to him.
I wonder about the side door. Doloff does mention side door on some Anglo-American clocks, but the one on yours does not go with the rest of the clock. Your description does it justice, so to speak. Why not at least match the veneer? Is it a replacement? And I do not find that the surround to the pendulum port is a favorable touch. The whole clock gives the impression of a one off case or the production of a "cottage industry." Or did someone take something and turn it into something else.? Of course, crudeness in the construction of parts that are hidden is not unheard of. Note the for instance the cutout for the movement in the clock in this thread.
All in all, I'm not much help!:screwball:
Jerome collector
Sep 4, 2005
969
159
Omaha, NE
Steven,
Thanks for your astute observations. Looking again at the door, I'm inclined to go with it being replaced. I compared the thickness of the door with the thickness of the case. Most telling is the wood forming the side of the clock is not of even thickness. The door, on the other hand, is more nearly even. Where the case is thick, neither edge of the door is a match. The door is a better match to the thinner side of the case. I'd noticed previously, but forgot to mention it in my original post, that none of the planks making up the case are of uniform thickness. If the door is not original, that makes the knicked corners (which do have curvature suggesting a drill hole) even more peculiar. Assuming this is not a top married to a later and cruder box, I think the signs point to a one-off or a cottage industry product. The absence of a label also strikes me as suggesting a more informal industry.
Although the hanger indicates it was meant to be a wall clock (or was at some point during its life), right now I have it sitting on a cabinet. It's quite stable and could easily be used as a shelf clock.
Steven Thornberry
User Administrator
Jan 15, 2004
25,693
2,695
Here and there
You know, Mike, what I would suggest, is a quick inquiry to Peter Gosnell, who is on the NAWCC Research Committee. He has done a fair amount of research on Anglo-American clocks and can undoubtedly give you a better analysis of your clock than I can. It is just unusual enough (if I'm right) to warrant a closer examination. It would be good to know.
A look through past Bulletin articles may also repay inspection, in the event a close relative of your clock has already been reported.
Jerome collector
Sep 4, 2005
969
159
Omaha, NE
Steven,
I've been toying with the idea of contacting Peter Gosnell, and I guess that's where I'll turn next. I've read all of his contributions to the Bulletin on Anglo-American clocks and didn't see anything quite like mine. I'll let you know if anything develops. In the meantime, if anyone else has ideas, I'd love to hear them.
Mike
jmclaugh
Jun 1, 2006
5,867
449
Devon
Afaik Anglo-American wall clocks first appeared in the UK around the mid 1800s with Jerome being amongst the first to export movements to the UK for use in them and I understand his son visited England and set up their own company in England, Jerome & Co, around that time.
The cases of these clocks tended to be of relatively cheap construction but were well veneered and often embellished with inlay, brass and mother of pearl and the like, much more so than their English fusee drop dial counterparts. This clock while obviously much plainer is not unlike examples of the genre except for the fact the bottom of the case is square unlike most which curve back towards the wall.
It is thought Italian workmen were involved in the production of the cases and two companies are known to have made cases for them. Holloway & Co of London and J.C. Plimpton of Liverpool, the latter is thought to have made cases for the company Jerome established in the UK and New Haven Clock Company.
Staff online
181,579
1,584,376
54,874
ltrrtl53
3,137
Pocket Watch Regulator by Kent
Top Bottom
