American Tall case WW correct weight
Discussion in 'Wood Movement Clocks' started by eculuke, Jun 29, 2018.
  1. eculuke
    eculuke Registered User
    Aug 11, 2014
    132
    I acquired a second Hoadley tall case (this is getting addictive). This one has no weights. Can anybody reccomend the correct weight and possibly a link to the weight on time savers or Merritts?
    Luke
  2. Peter A. Nunes
    Peter A. Nunes Moderator
    NAWCC Fellow NAWCC Member Sponsor
    Mar 3, 2006
    1,653
    14
    Restorer of antique clocks.
    Rhode Island
    The strike side will run on two pounds or less, the time side on three or four pounds. Most of the weights I see are much heavier, and unnecessarily so. Antique weights often show up on eBay. The shells Merritt's sells are very good, but but very new and shiny.
  3. eculuke
    Aug 11, 2014
    132
    Peter thanks for clearing that up.....now to find a set somewhere...ha
  4. Peter A. Nunes
    Mar 3, 2006
    1,653
    14
    Rhode Island
    Be patient, they do show up. If you're going to National, you might find a set on a table in the Mart.
  5. tom427cid
    tom427cid Registered User
    Mar 23, 2009
    1,595
    80
    Cabinetmaker,clock repair
    Moultonborough,NH
    Hi all,
    Another solution short of original weights,I use old brass or brass plated weight shells cut to an appropriate length and I can use different diameters if I want. I make caps out of wood,one I drill a hole and use an 1/8th inch brass cotter pin to hang the weight. Then some flat black,red,and brown spray paint,roughly wiped off when still wet. The result is passable. Another is cut down sash weights.
    Just thought I'd add.
    tom
