American Hamburg Chess Timer mainspring
Discussion in 'Clock Repair' started by CJo, Feb 28, 2019.
  1. CJo
    CJo Registered User
    Aug 22, 2005
    400
    Operator in an Ethanol plant. I train new operator
    southwest Kansas.
    What is the best way to let down the mainspring on one of these clocks? Would appreciate any advice.
    IMG_2969.JPG Thanks
  2. Uhralt
    Uhralt Registered User
    4,303
    453
    Make a special let down tool: Take a 4 inch piece of broomstick. Center drill with a drill bit slightly larger than the diameter of the key rod. Drill about an inch deep. Cut a slit across the hole, just a bit wider than the handle of the key and a bit deeper than the handle is deep. You want to get a section of the key rod to fit into the center hole. Push the tool on the key with the handle in the slit, hold it and release the click to let down the spring.
  3. CJo
    CJo Registered User
    Aug 22, 2005
    400
    southwest Kansas.
    Thank you very much, Uhralt, I appreciate your advice. I will do that.
