Repost your question in the Watch repair section.Hello Again,
I'm servicing this watch and noticed two problems:
1) the mainspring is "set" so I'm looking for a replacement. Curiously, the height of the spring is 2.80 mm instead of the usual 2.7 mm (thickness is 0.186mm and length is 20.5"). I'm tempted to get the #47315 (JA-410) which is 2.7mm but there is also a 2.9 mm spring for "thick barrels" 47333 (JA-419). Which should I get?
2) there is one cracked jewel for the third wheel. Suggestions to where to source a replacement?
Michel
Thanks for the tip. I did post a similar thread on that forum as It looked it wouldn't get much traction here. I did obtain answers to my questions.Repost your question in the Watch repair section.
I could move it there, but it might be confusing to split this thread.
Rob
