ALPHABETICAL LISTING OF ARTICLES IN THIS FORUM
Status
Not open for further replies.
musicguy
Jan 12, 2017
7,598
4,119
New York State
ALPHABETICAL LISTING OF ARTICLES IN THIS FORUM AS OF OCTOBER 7, 2019
Created by bangster
3-D Printing of Clock Parts
A
Adjusting Swinger Clock To Tell Accurate Time
Adjusting the J-wire Strike •
Adjusting & Making a Dead-Beat Verge •
Alarm Clock, synchronizing time & alarm •
All About Pendulums
Ansonia count-wheel strike setup
Arbor Hook - Replacing a broken •
B
Bill Stuntz on cleaning without disassembly •
C
Calculating the Size of a Mainspring •
Chime Rod Removal Tool •
Chime Sequence is off on ODO Mantle C
Clock Parts Terminology •
Cuckoo Bellows Patterns •
Clock Suppliers -- General/Supply/Tools/Repair/Service/Etc. •
D
Dealing with the Sessions 2-train Chime Movement •
Disassembling an American Time & Strike Movement •
Disassembling a Hermle 261-080 Two-train movement •
Drilling Brass •
Dovetailing for Tooth Repair •
E
Encyclopedia Articles on Clock Repair •
Encyclopedia, How to Access •
F
Floating Balance, All About •
G
Gong, Making a...101
Grand Sonnerie Movement Explained •
Gustav Becker Two Weight Movement Tips •
H
Hermle Chime-Strike Setup •
Historic Timekeepers Cleaner
How to repair a quartz movement •
How A Pendulum Clock Works •
K
Kitchen Clock Alarm •
L
Lantern Pinion Repair
M
Mainspring Chart •
Mainspring -Servicing Full-Length •
Mainspring, Installing a "C" restraint •
Mainspring, measuring length of •
Mainspring, Re-holing •
Make Your Own Liquid Hide Glue
Making New Vulliamy Pallet Nibs
Making Vuillamy Deadbeat Pallets
O
Oil a clock, How To (5 pages) •
P
Pendulum Swing with Deadbeat Escapement
Pendulums, All About •
Putting an even patina on Brass
Pivot-Polisher/Turns from a door hinge •
Putting a Swinger Clock in Beat •
R
Rack Hook Landing on the Point of a Tooth
Removing the Numerals from an Ansonia Ball Swinger
Re-Pivoting; Using the Center Finder •
Reducing pendulum swing of quartz movement
Replacing Barrel Hook •
Reassembling a Clock Movement •
Replace the Click Spring in a Hermle Sprocket Wheel •
S
Searching the Message Board using Google •
Setting the Beat of a Swinger Clock
Shellac, All About •
Singing Bird Automaton •
Smoothing Broaches, making your own •
Spring winder instructions:Keystone, Webster and Joe Collins
T
The cannon pinion
Three-D printing of Clock Parts
Tumbling Chains, etc., to Polish Them
TAMING THE SESSIONS TWO-TRAIN CHIME MOVEMENT
The Westminster Chime Note Sequence•
U
Useful Hints and Tricks •
Using a Compass to Locate Hole Centers
Using the old anchor to pattern a replacement.
W
What Makes a Clock Run Slow? •
Winding Key Letdown Tool
Winding Key Sizes •
Reactions: Allen P Choutka
Status
166,237
1,448,389
86,754
brightsparkey
2,907
