AhHa cad cam software and control board
Discussion in 'Clock Repair' started by clocks55, Jan 7, 2015.
  1. clocks55
    clocks55 Registered User
    Oct 1, 2008
    45
    clock repair and antique clock sales
    8 Hillcrest Lane Saratoga Springs NY 12866
    I have a friend, my mentor, John Kocsis, who has used this AhHa software version 4-1to make clocks on an x-y milling machine for 15 years. The company is our of business and his board was partially burned out. He needs parts and advice. He is 85 and does not have access to the internet. If you can help please contact me and I will put you in touch with him. He has been the main support to chapter 40 nawcc for more than 30 years and we are all trying to help him as much as he has helped us, thank you, Peter Elmendorf
  2. Tinker Dwight
    Tinker Dwight Registered User
    13,666
    70
    Several questions are needed.
    Where is he?
    What type of computer does he have?
    How do you know parts are burned out, did you see smoke?
  3. John MacArthur
    Feb 13, 2007
    350
    29
    One of my machines uses an old AhHa power supply, but all the drivers burned out -- I replaced them with Gecko drivers, and it works fine. It takes some doing, though, and better cooling than the original had, at least for larger step-motors. He'd wind up with a pretty good chunk of change in it, and there's probably some used Flashcut stuff on Ebay.
    John MacArthur
  4. clocks55
    Oct 1, 2008
    45
    Hi Tinker, he is in ny state off exit 10 of the northway route 87, about 15 miles north of Albany. He has a Dell computer. Yes he saw smoke. He knows he needs some IC's. Thanks, Peter
  5. clocks55
    Oct 1, 2008
    45
    Thank you John, Peter
  6. Tinker Dwight
    13,666
    70
    Too far from me. Is it the computer or the stepper drivers that
    are burnt? Not fun if either. Most older software will only run on
    older machines.
  7. clocks55
    Oct 1, 2008
    45
    It is the stepper drivers, it is an older computer, Peter
  8. John MacArthur
    Feb 13, 2007
    350
    29
  9. clocks55
    Oct 1, 2008
    45
    John, Thanks so much, Peter
