After the fire
Discussion in 'Clock Repair' started by wow, Nov 8, 2018.
  1. wow
    wow Registered User
    Jun 24, 2008
    4,282
    327
    Retired Music Minister
    Pineville, La. (central La.)
    I got in a nice marble Frenchie that had been in a fire. Looks like everything is gonna clean up fine. The only thing that is a question for me is this dial. It appears to be solid brass with smoke/ash/whatever coated on it. I don’t know what to use to remove the gunk without removing the painted numbers. Naphtha got it off the porcelain center section of the dial, but I’m afraid it would resolve the paint. Help?
  2. bruce linde
    bruce linde Technical Admin
    7,125
    906
    oakland, ca.
    clean it up and just have the numbers repainted. i have a dial painter who did the same for me... don’t think it was more than $50.
  3. dad1891
    dad1891 Registered User
    Feb 28, 2014
    600
    Denver, Colorado
    A long time ago I was in a building that had a fire and everything was coated with smoke. Asked the fire dept what the best way to clean it would be. They recommended a mixture of Arm & Hammer Super Washing Soda and Tide. Works great! I would suspect that it would not remove paint, but I would definitely test before using. Bear in mind that anything other than incidental use also removes skin. I would start with a cup of each in a gallon of water. Rinse well. Don't use on aluminum.
    It's not always easy to find, but it is usually very inexpensive. Here's what it looks like.
  4. Dick Feldman
    Dick Feldman Registered User
    Sep 1, 2000
    2,252
    119
    Colorado, usa
    If you visit an art supply store, you may find they have numerals matching the size and style. Normally these come as rub on transfers that can be lacquered afterwards. Take your dial with you to pick out the numerals. They may have a catalog and those may have to be ordered.
    Best of luck,
    Dick
  5. Fitzclan
    Fitzclan Registered User
    Jul 20, 2014
    648
    24
    Long Island, New York
    ppache likes this.
  6. wow
    wow Registered User
    Jun 24, 2008
    4,282
    327
    Thanks for all the suggestions. I’ll begin with the baking soda/Tide method and report back.
  7. Joseph Bautsch
    Dec 9, 2006
    1,113
    125
    Atlanta, GA
    There are a lot of smoke and water damage clean up and restoration companies, even in Pineville, LA, who might be able to help. They have the cleaning procedures and cleaners that will probably do the job. I have no idea what they would charge for a small job but they might give you advice on how to do it yourself.
  8. wow
    wow Registered User
    Jun 24, 2008
    4,282
    327
    Well, the baking soda/ Tide solution worked great to remove the sludge from the fire, but the brass is tarnished needing polish. I polished it and it looks great, but the numbers came off. I will now use the rub-on transfers. Should work fine. Found some that match the originals. Will post final results.
  9. Bruce Alexander
    Sponsor NAWCC Brass Member
    Feb 22, 2010
    7,011
    658
    I'm sure it will be a vast improvement Will. It looks like there was a lot missing from the numbering before you got started with your cleanup/restoration anyway. I look forward to seeing your before and after comparisons.
  10. kinsler33
    kinsler33 Registered User
    Aug 17, 2014
    3,370
    400
    Science teacher, writer
    Lancaster, Ohio, USA
    I sure wish there were ways to restore or at least stabilize dials that are painted directly onto the dial pan and are now flaking off.
    That, and a way to somehow restore paper dials without just buying another to paste over it.
    And silvered dials, too. Were those just silver-plated, or what?
    Mark Kinsler
  11. Bruce Alexander
    Feb 22, 2010
    7,011
    658
    #11 Bruce Alexander, Nov 10, 2018
    I haven't tried it personally but Soluvar varnish is supposed to be a good stabilizer.
    Photograph, digitally "restore" the original, laser print (not ink jet on archival quality card stock) and replace (or reversibly cover) the original. That is about the closest I've come to doing something along the lines of restoring a paper dial. I'm betting that museum curators could speak to paper restoration/conservation methods.
    I think that the process is called displacement plating.
    "Dissolve a stick of nitrate of silver (or here) in half-a-pint of rain water (just use distilled); add two or three tablespoonfuls of common salt (non iodized), which will at once precipitate the silver in the form of a thick, white curd, called chloride of silver. Let the chloride settle until the liquid is clear; pour off the water, taking care not to lose any chloride ; add more water, thoroughly stir and again pour off, repeating till no trace of salt or acid can be perceived by the taste (not so sure I would do a taste test). After draining off the water, add to the chloride about two heaped tablespoonfuls each of salt and cream of tartar, and mix thoroughly into a paste. which, when not in use, must not be exposed to the light. To silver a surface of engraved brass...[discussion of waxing and preparing brass dial's surface]...Rinse the brass thoroughly, and before it dries lay it on a clean board, and gently rub the surface with fine salt, using a small wad of clean muslin. When the surface is thoroughly covered with salt, put upon the wad of cloth, done up with a smooth surface, a sufficient quantity of the paste...rub evenly and quickly over the entire surface. The brass will assume a greyish, streaked appearance; add quickly to the cloth cream of tartar moistened with water into a thin paste; continue rubbing until all is evenly whitened. Rinse quickly under a copious steam of water; and in order to dry rapidly, dip into water as hot as can be borne by the hands and when heated, holding the brass by the edges, shake off as much of the water as possible, and remove any remaining drops with a clean, dry cloth. The brass should then be heated gently over an alcohol lamp, until the wax (discussed previously) glistens without melting, when it may be quickly covered with a thin coat of hard spirit varnish, laid on with a broad camel's hair brush." Source: "Watch and Clockmakers' Handbook, Dictionary and Guide" by F. J. Britten First published in 1915. [please excuse any typos]
    OR, you can just order silvering kits from one of many Supply Houses. The Kit approach I've tried and it does work quite well even if you pay for the convenience of ready made Silver Chloride salt and Cream of Tartar powder (which you can buy at any grocery store).
    Does that help or did I miss your question entirely?
    Bruce
  12. wow
    wow Registered User
    Jun 24, 2008
    4,282
    327
    Well, here’s how it turned out. Dad’s solution of Tide and Laundry baking soda cleaned off the gook well. After polishing all the brass, the numbers, of course, were gone. I used rib-off transfers and then sprayed four coats of matte lacquer on it. Came out better than expected. Customer is going to love it. It’s a family heirloom that he thought was ruined in the fire. Thanks for all your help. What would we do without the MB?
    5982898E-462A-4E8B-AA68-5912A76D4E4A.jpeg D889790F-9628-48C8-932C-7ECBBA742A30.jpeg
    Dave T and Time After Time like this.
  13. shutterbug
    43,786
    1,282
    Looks great, Will! Nice job!
  14. Joseph Bautsch
    Dec 9, 2006
    1,113
    125
    Atlanta, GA
    Agreed, great job. I've never had much luck using the rub-on numbers, but you did a really good job. The customer should be delighted.
