Advice
Kent Burke
Sep 22, 2020
I'm a newbie to the horological field, so please excuse my ignorance with proper terminology {which is important, i understand} etc. I have an introductory DVD course that shows me the basics, but I've run into a snag due to every watch looking different to me. So here goes: I am currently disassembling and cleaning a 16 size Elgin pocket watch but have run into problems with the new mainspring installation. According to a previous thread I posted, someone did tell me that I bought the right replacement spring, so I've discounted that as a possible error on my part. I installed the new mainspring by hand but can't get the cap of the barrel to snap back in place securely. I can only assume that perhaps I've inadvertently kinked it somehow upon installation. I've since taken it out and it doesn't {to my untrained eye at least} appear to be damaged in any way. I'm coming to the conclusion that I'm going have to purchase a mainspring winder to do it properly {and maybe even a new mainspring} but I have no idea what to get. I'm on social security so my funds are limited and I certainly can't afford some fancy set with a myriad of sizes to choose from. I'm starting to think that this is the wrong hobby cause of the cost associated with some of the tools, however I refuse to give up so easily. I acquired a lot of the basic tools needed when I lived in a city where I could attend meetings of fellow enthusiasts but now I'm in an area that seems to devoid of that kind of help - hence I'm pretty much on my own now except for this forum. To get to the point, I'm willing to buy an inexpensive winder, but as is usual with everything these days, there is entirely too much information/options out there to make an uneducated decision on what to consider getting. This post is quite lengthy, but I wanted to explain myself as some of you may have been in a similar situation and wouldn't mind offering some advise.
roughbarked
Dec 2, 2016
5,924
784
OK.
If you purchased the right replacement spring then something is coming out of the left field here. ;)
The first thing I'd think of is that the replacement spring is too high and of course that can be checked. The barrel lid needs to have enough clearance from the mainspring to be able to clip into the groove placed there for the purpose.
gmorse
12,334
2,031
Hi Kent,
Are you sure that the arbor is seating properly in the base and lid? Sometimes the centre coil of the spring can push the arbor over to one side so that it doesn't immediately enter the hole in the lid properly.
Reactions: roughbarked
Skutt50
Mar 14, 2008
3,783
209
Gothenburg
Can you measure the old spring and compare with the new?
Also make sure that each turn is seated in the barrel. It is enough if just on turn is a bit too high.....
Kent Burke
Sep 22, 2020
The old mainspring measures the same as my replacement - .104, thanks
Skutt50
Mar 14, 2008
3,783
209
Gothenburg
When you took the old spring out, did you have to prey the lid open? If so the old spring was probably working correctly at one time.
If the old spring fitted fine the new (with the same measurements) should fit as well........
I don't think a mainspring winder will make any difference. It is good practise to use one when installing a mainspring, since handwinding may cause a slight cone shape to the mainspring.
Just make sure each turn is pressed down towards the bottom of the barrel. The lid can be a bit hard to close. Sometimes you need to use a pair of pliars...... (Careful not to cause any damage!)
Jerry Treiman
Golden Circle
Aug 25, 2000
6,671
2,600
Los Angeles, CA
You will note that this mainspring has a tab extending out from both sides of the outer end of the spring. These two tabs must nest into the corresponding slots in the barrel and the barrel cover. Otherwise the cover will not close properly.
164,853
1,434,456
85,821
ClockWonderer
2,867
