Advertising Clock Question
JoyF
Jun 4, 2013
213
I hope these pics show the situation. The minute hand slides on fine, but the second hand is loose and there is nothing to secure it with. How could I fix this? Thanks. 313278.jpg 313277.jpg 313279.jpg
- - - Updated - - -
kinsler33
Aug 17, 2014
3,491
429
73
Lancaster, Ohio, USA
I wonder if that second hand used to have a brass hand bushing in it. Depending on your level of skill you may be able to devise a new one.
M Kinsler
senhalls
303
24
western PA.
I think the hands have been changed. The minute hand should have a hole with two flats secured with a nut. Then you could run the minute hand around to set the time. The smooth steel pin would take a sweep second hand. No?
44,358
1,360
Many of those older second hands screwed onto the shaft. It looks like it is or used to be threaded.
JoyF
Jun 4, 2013
213
I'm fairly new to this, but this may be a help http://timesavers.com/search.html?q=hand+bushing&go=Search
If you're not overly attached to those hands, you could get some replacements fairly cheap, and probably about the same design. I'm also assuming you meant hour and minute, rather then minute and second?
Yes, I'm sorry, I meant hour and minute hand. My mind hasn't been very clear lately. Thanks for the link to that website.
JoyF
Jun 4, 2013
213
I think it may have been a screw-on hand. The current hand does not have apparent threads.
The clock is a Red Chain Feeds advertising clock. You can google and find a couple pictures in Images. After looking at that again, it appears that there is supposed to be a second hand that attaches last.
I'd like to replace all of the hands as the hour hand looks to have a crack in it also. Do most replacement hands of this type fit any older clock?
It is a spin-start clock. Thanks.
12,774
987
Not many electric hands available anymore. Intermatic, Hansen and Lancashire were the last ones still standing, that I know of.
Keep in mind that most larger second hands will have a brass bushing with LEFT HAND threads. There are some second hands that push on, usually on smaller dials.
44,358
1,360
It looks like your movement might accept regular I shaft hands. You might have to do some minor alterations, but it's worth a look-see.
bangster
19,876
443
What senhalls said above. That's the wrong minute hand for the clock.
JoyF
Jun 4, 2013
213
With a dial such as this, how long should the minute hand be? Would I consider the dial as having a chapter ring? Depending on whether I measure from numeral to numeral or chapter ring diameter, my hands would be either about 4" or 5". Also, length of second hand in relation to minute hand? Thanks. 313679.jpg
44,358
1,360
I'd go 1/2" shorter than what you have. An inch wouldn't be terrible if that's what you can get.
JoyF
Jun 4, 2013
213
Found an hour and minute hand set that should work. My second hand shaft size is about .072". The second hand on the website I was going to order from has an inside shaft diameter of .030" - .031". Any suggestions as to how I could remedy this difference? Thanks.
44,358
1,360
Can you broach it? Or drill and thread it?
Topic related ad experiment
