Hello! Just a disclaimer, I am vastly unfamiliar with much of the inner-workings of clocks and need some help. I have only built a simple Graham Escapement clock, previously. I need to build a clock that triggers a single signal to occur three times at equally spaced time intervals. These time intervals need to be adjusted after each trial for a total of three trials (we are only given five minutes to adjust). I was looking into striking clocks, but I am unsure of whether you are able to adjust the interval at which it strikes or if it is even doable considering my inexperience. I have also considered adding a lever system that triggers a visual signal, but the dropping weight does not strike the lever with enough force to trigger it. Currently, I am trying to research more into it, but I find it hard to understand a lot of material. A bit of advice would be greatly appreciated!
