• Upcoming updates
Adjusting Herschede Grandfather Clock Chimes and Strike
Dick Feldman
Sep 1, 2000
3,349
631
Colorado, usa
Please also look at my latest video to see if there is something else I should do. The strike will not release unless I help it. In the video I push down on the chime shutoff to release it. Thank you.
Is the movement completely assembled?
The problem may be with the chime correction part of the movement (integral pieces not installed).
Herschede movements are kind of quirky and did not operate within normal bounds.
Your solution should be found in Conover's writings on that movement.
Have you read and studied the chime/strike sequence with those writings?
If ever I am faced with a problem that I evidently cannot solve, (This is post number 51 on the subject) I will hit the books or send the movement to someone more qualified.
Is this your clock or are you learning on someone else's clock?
Best,
Dick
AlpineTime
Jan 31, 2016
34
7
I'm late to the party, here, but for what it's worth I'll return to the lost power issue for a moment.
When I reassemble a movement for the first time after making pivot and bushing repairs., I leave off all external levers, pin drums, etc. and spin the internal wheel trains, dry, with the gentlest pressure on spring barrels or cable drums. I spin both ways and watch all the pivot ends for lateral movement, and I listen. The slightest sign of resistance indicates a bent pivot or tight bushing. A moving pivot end or chatter indicates a too-loose bushing. Any of these indications causes me to separate the plates and fix the offending pivot or bushing. They only get harder (and more annoying) to find and fix after external loads and oil are added.
I find this is an especially essential procedure for power-hungry Herschede movements, whether they be for tall clocks or mantel clocks.
wow
Jun 24, 2008
7,140
1,363
77
Pineville, La. (central La.)
In the last video it is clear that the strike train is not releasing after the warn. Look at the position of the locking pin on the wheel in that train. That pin is not being released by the tab on the lever?
Naif Baidoon
Nov 24, 2019
124
70
Just some final adjustments needed on the chime roll, hopefully the self correcting lever takes care of it. JB Weld still holding the chime pallet on. Chime tubes seem to need tuning but I will wait until I get things synced up correctly.
Thanks everyone for your inputs and ideas they are always very helpful.
180,087
1,571,001
54,369
wbaNev
911
3,103
