Adjusted? Adjusted 6th position?
Discussion in 'American Pocket Watches' started by kd8tzc, Apr 19, 2017.
  1. kd8tzc
    kd8tzc Registered User
    Apr 11, 2017
    61
    Sorry guys if this is out there someplace, but I didn't have much luck searching for it. I keep seeing these terms in some of your posts and I have no clue by what you mean when you say you have "such and such watch, adjusted" or that the watch was never adjusted to the 6th position. Can someone give me a quick rundown on what this all means (or point me to a post that explains all this terminology).
  2. topspin
    topspin Registered User
    Dec 14, 2014
    1,158
    If you find (or imagine) a watch which is in poor condition (or simply, badly designed or cheaply made) then its timekeeping may vary according to a number of factors, including -
    What position it is in (face up, face down, stem up, stem down, sideways/diagonally, etc)
    Whether it is fully wound or nearly unwound (lack of "isochronism"), and
    Variations in temperature (heat, cold.)
    ...so basically you can't rely on it to always be telling the correct time.
    If you now imagine a newly-made watch still at the factory - "adjustment" was a slow process of assessing its timekeeping in various circumstances, and then adjusting it as necessary.
    More adjustment = more expensive, in return for (hopefully) better accuracy.
    As far as I am aware, there was no standard list of "Position 1 is this, Position 2 is that (etc)" common to all the manufacturers.
  3. Kent
    Kent Registered User
    #3 Kent, Apr 19, 2017
    Perhaps you'll find the Encyclopedia article entitled "[main="Watch Adjustment"]Watch Adjustment[/main]" to be helpful.
    You may also find the following Encyclopedia articles useful in understanding pocket watches and the terms that are used in discussing them:
    • [main="Case Type"]Case Type[/main]
    • [main="Movement Type"]Movement Type[/main]
    • [main="Pocket Watch Dials"]Pocket Watch Dials[/main]
    • [main="Pocket Watch Jewels"]Pocket Watch Jewels[/main]
    • [main="Pocket Watch Regulator"]Pocket Watch Regulator[/main]
    • [main="Setting Watch Hands"]Setting Watch Hands[/main]
    • [main="Watch Case"]Watch Case[/main]
    • [main="Watch Grades"]Watch Grades[/main]
    • [main="Watch Models"]Watch Models[/main]
    • [main="Watch Runs"]Watch Runs[/main]
    • [main="Watch Size"]Watch Size[/main]
    • [main="Watch Chain"]Watch Chain[/main]
    The Encyclopedia articles listed in these links may also be helpful to you, especially the items and links listed in each article's References section.
    And perhaps you will find the following Encyclopedia articles useful:
    • "[main="Railroad Time Service"]Railroad Time Service[/main]"
    • "[main="Railroad Watch"]Railroad Watch[/main]"
    Please feel free to ask about anything that isn't clear to you.
  4. terry hall
    terry hall Registered User
    Apr 12, 2001
    6,419
    illinois
  5. kd8tzc
    Apr 11, 2017
    61
    Thanks all... that's quite helpful. Is the watch stamped/marked someplace that it is adjusted or was that only in the advertisements? I guess, how would you know?
  6. Kent
    Most are marked. Your question is answered in detail, with links to pictures, in the [main="Watch Adjustment"]Watch Adjustment[/main] Encyclopedia article.
Similar Threads - Adjusted Adjusted position Forum Date
Any listing of Late 30's Elgin grade 478 marked adjusted to 6 positions? American Pocket Watches Sep 3, 2017
Interesting 12s 17j G M Wheeler with Adjusted twice engraved on movement American Pocket Watches Jul 3, 2017
Found a nice 16s adjusted 15j 1881 Elgin Grade 4 American Pocket Watches Mar 17, 2017
Adjusted to position - how consistent should a watch be in various positions American Pocket Watches Dec 21, 2016
Howard Railroad Pocket watch , 5 position extra ? adjusted , need lot of info , thank American Pocket Watches Nov 28, 2016
