ATO Kundo Adding circuit board to Kundo ATO
Discussion in 'Electric Horology' started by rudiedog, Jan 7, 2018.
  1. rudiedog
    rudiedog Registered User
    Nov 12, 2013
    Illinois
    OK, forgive me, electronics is not my thing....at all. I have one of the Kundos with a transistor that has given out. I see someone on E-bay is selling brand new circuit boards for these clock that had them. Could I just add one to my clock? Wouldn't the circuit board do what the Germanium transistor did?
  2. etmb61
    etmb61 Registered User
    Oct 25, 2010
    2,478
    167
    Retired Avionics Technician
    Mascoutah, IL
    You may still need to change or rewind the coil as well. That being said, I have not seen the circuit diagram for the clocks with the external board.
  3. praezis
    praezis Registered User
    Feb 11, 2008
    463
    27
    Germany
    I doubt that this.circuit will work in your clock. It needs access to both ends of one coil without a (broken) transistor in between.
    Frank
  4. rudiedog
    Nov 12, 2013
    Illinois
    Bummer!!! This would have been such a Godsend to many of us with end of life clocks. Well, I guess it is back to the work-around in the video posted in another post.
  5. David S
    David S Registered User
    Dec 18, 2011
    7,198
    245
    Brockville, On Canada
    Hi guys I have some germanium transistors in TO-5 cases. Anything special? Certainly would be willing to part with some if they can help.
    PNP or NPN?
    David
  6. MartinM
    MartinM Registered User
    Jun 24, 2011
    3,053
    102
    El Dorado, CA
    There are folks who've tested and found that steel cased versions cause problems. I don't know if anyone ever said anything about aluminum.
    The original clocks used a glass S02 case.
  7. jcosta-co
    jcosta-co Registered User
    Apr 4, 2011
    107
    Arvada, CO
    #7 jcosta-co, Jan 26, 2018
    I have collected a number of circuit diagrams for the Kundo electric clocks over the past few years. Here are some I have found.
    John
    The values of the electronic parts are from my Kundo clock,
    the values in brackets are from the German patent 1.773.306A
    German patent 1.178.015
    US patent No. 3.118.098
    Kundo Tapped Coil
    2,000 & 600 Ohms
    Kundo Drive Circuit by Ron Elliot
    Sensor coil – 5,000 turns, #42
    Drive coil – 3,000 turns, #42
    Silicon transistor
    PNP BC258B silicon
    NPN BC168B silicon
    This circuit is not mine. It's from Rod Elliott's website.
    It can be found here.... http://sound.westhost.com/clocks/motors.htm
    PNP (Si) transistor: 2N3702 (TO92)
    MMBT4126 (SOT23)
    NPN (Si) Transistor: 2N5172 (TO92)
    MMBT5089 (SOT23)
    David S likes this.
  8. David S
    Dec 18, 2011
    7,198
    245
    John very nice summary of various electronic clock circuits. I think this post deserves its own thread and title for easy future searching.
    David
