Actual Beats per Hour is +10 over the wheel Count!!!
bchaps
Dec 16, 2001
1,130
14
Mountain Top, PA
www.clockguru.com
I am baffled. After verifying the wheel count on a Jauch 3-Train, the BPH should be 4052.14. But I noticed at that rate, it was losing time slightly. So using a Microset Timer, I did a beat count for precisely 9 hours: (starting from the release of the 4th qtr chime and ending at the point 9 hours later). After dividing the total beats by 9, I get 4061 actual BPH :???: The hands are tight - no center arbor slippage here. Any thoughts why it needs an additional 9 beats each hour? thank You, Bill
bchaps
Dec 16, 2001
1,130
14
Mountain Top, PA
www.clockguru.com
MARK A. BUTTERWORTH
NAWCC Life Member
Jul 4, 2009
2,479
151
Muscatine, Iowa 52761
This is not unusual. Even though the hands seem to have enough tension, sometimes, in fact, there is not enough tension on the center shaft to turn the starwheel forcing the chime train to unlock without some slippage on the part of the center shaft. You might also see if there is some extraordinary friction reuiring the unlocking of the chime train- smooth and grease all the levers that are sliding, etc.
eskmill
Aug 24, 2000
7,135
I have a strong suspicion that the reason for the nine extra pendulum strokes over the nine hour period will be evident if you connect the MicroSet timer to a computer to graph and observe the short-time accuracy of the Jauch chime clock.
I think you'll see inconsistent variation in the rate over short periods of an hour or less.
The force of the driving weight changes slightly over a period of a day due to the weight of the chain.
Too, temperature shifts over an eight hour run will affect the rate.
The simple infra-red optical interrupter is somewhat affected by ambient light; sunlight especially.
I don't think a variation of nine pendulum strokes out of a total of over 36,000 is significant error for a chime clock movement on the workbench.
bchaps
Dec 16, 2001
1,130
14
Mountain Top, PA
www.clockguru.com
Mark and Les...Thank You! My brain was thinking gears don't slip. But, I was not considering about the extra force required to release the chime lock, which may cause some slippage. I have lubricated all sliding levers. Les, this movement when graphed with the Microset has an instability of 9 seconds per day which I attribute to the chime release. Now that I've bumped it up to 4061 BPH, it seems to be holding perfectly. Thank You again, Bill
166,306
1,449,007
86,808
TopherDale
2,910
