Accutron repair manual
Discussion in 'Wrist Watches' started by doug sinclair, Mar 8, 2001.
  1. doug sinclair
    doug sinclair Registered User
    Aug 27, 2000
    14,364
    50
    Calgary, Alberta
    Thomas,
    These technical service manuals show up frequently at NAWCC marts. If you are a member, keep your eyes peeled.
    As for the Accutron on which the seconds hand moves but the others don't. You probably have a model 218 or a derivative therefrom. This is a common problem with these, especially if the case has ever leaked moisture. The minute pinion assembly (cannon pinion) on these is the problem. This assembly has a typical cannon pinion with a larger drive wheel a friction fit on the bottom end. The pinion portion turns on a hollow idler post through which the seconds arbor runs. The problem is usually RUST between the idler post and the pinion. When this happens, the pinion seizes while the drive wheel on the lower end of the pinion keeps turning! This results in the phenomenon you are seeing. Unless you are very experienced in repairing watches, it might be an idea to have it done!
    Doug S.
  2. Julian Smith
    Julian Smith Registered User
    Sep 1, 2000
    823
