Acceptable gain or loss for timekeeping, weekly.
Discussion in 'General Clock Discussions' started by Kevin W., Apr 5, 2008.
  1. Kevin W.
    Kevin W. Registered User
    22,015
    268
    I just checked my Urgos box clock tonight.It was slow by about a minute and a half.
    is this decent time keeping?
    What is a vaerage for a week for a good running clock, american or german made.I realize the higher end clocks likely do keep better time than my Urgos.
  2. Scottie-TX
    Scottie-TX Registered User
    Apr 6, 2004
    936
    Mesquite, TX
    I think you'll find replies vary widely. Very subjective - what collectors seek or accept. I'm not an accuracy zealot. A few mins. a week keeps me happy altho you KNOW I'll be shooting for the moon when this pinwheel is finished and on display. Again and also; I'm sure expectations vary for particular clocks.
  3. leeinv66
    leeinv66 Moderator
    Mar 31, 2005
    9,739
    170
    Industry Specialist
    Launceston Tasmania
    For me, it depends on the type of movement. Spring clocks, up to 4 minutes a week if they are American or up to 2 minutes a week if they are German or English. Weight clocks, less than 1 minute a week, no mater where they are made. But as Scottie said, different folks will have different expectations.
  4. harold bain
    harold bain Registered User
    NAWCC Member Deceased
    40,850
    149
    deceased
    If you have the patience, you can get it down to within a minute or so, but only adjust the regulation once a week on winding day.
  5. Thyme
    Thyme Banned
    Sep 18, 2006
    3,948
    metro NY area
    Ah, yes. A Jacquot pendulum taught me that. :clap:
    I get really nervous when most of my 25 (or so) clocks are all running accurate to within one or two minutes per week. :eek: I guess I'm doin' sumpthin' right. That's due to a weekly fine adjustment of the pendulum bob. :thumb:
    Of course, sometimes some will drift suddenly to about 5 minutes per week, with no apparent reason. Then I wonder why: is it temperature, changes in humidity, barometric pressure, or all of the above? :???: No matter what - we can't change those factors much, can we?
    I have one clock with VERY worn, sloppy bushings, yet it keeps accurate time to a minute or two per week (!). When it stops running, I'll re-do the bushings... So what's the hurry? :???: :?|
    Even so, considering when these clocks were made, over a century ago, maintaining 1-5 minutes per week fluctuation was considered "state of the art" technology then; and time (and the way it was perceived) for those who lived in that period, only needed to be accurate, not precise.
    Historically, that's something to ponder...
  6. Mike Phelan
    Mike Phelan Registered User
    Dec 17, 2003
    9,836
    15
    West Yorkshire, England
    Kevin
    I'd just reinforce what Scottie says and summarize:
    Actual timekeeping depends on:
    • Room temperature
    • What sort of clock it is
    • How well maintained it is
    • How often it is wound (unless it is electric)
    • If synchronous electric, how good is the accuracy of the power supplier?
    Acceptable timekeeping depends on:
    • Yourself!
    Quartz thowaway versus iron gothic clock with verge and foliot - which one would you rather have? I know which!
  7. Steven Thornberry
    Jan 15, 2004
    21,451
    831
    Ne’er do well
    Here and there
    I would also chime in (no, not that) that my expectations are lower for spring-driven hairspring movements than for spring-driven pendulum movements. Generally, I am correct in having such lower expectations. That said, however, I have a couple of Ingraham hairspring banjos that are very accurate (and consistent) throughout the week. So much so, that I am afraid to fiddle with the regulation in even the slightest degree for fear that I will hex the whole damn thing! Now having said that, I expect them to go all to hell this week.
  8. Kevin W.
    22,015
    268
    I expect my weight driven clocks to be more accurate than my spring driven.In most cases the clocks i compare to each other have been repaired where needed and cleaned and oiled.
    On a side not i have seen watches run very accurately that have not been cleaned or oiled for years.
    All good points given here. :cool:
  9. Mike Phelan
    Dec 17, 2003
    9,836
    15
    Watch movements are sealed against the environment better than most clocks, maybe?
    In theory, all other things being equal, weights are better than springs for timekeeping, except maybe for fusees.
    However, that only applies if you take the sentence above into account.
    Examples would be: spring-driven French mantel clock with Brocot escapement - 1 minute per week, weight-driven lantern clock with verge and balance wheel, 45 minutes per week!
