Looking for plans and part to build Aaron Willard shelf clock plans also know as Massachusetts Shelf Clock” by Aaron Willard Find clocks for sale but no plans or parts, like movements and dial (face) Hope you can help, would like to make this a project to do with my 2 boys (17 & 13) introduce them to woodworking. I am also planning to work on a Newport Tall case again where can I purchase painted face (dials) and movements Thank you for your time John
John, Both of these clocks would make a great construction project. I am not aware of a source for these exact plans. However, you might give the American Clock and Watch Museum a try. When I visited the museum in Bristol, CT several years ago, they had a large selection of clock case plans for sale. Many are available on their website. If you do not find what you are looking for, you might give them a call. Good luck on your search, Allan
While not an Aaron Willard Mass shelf clock, here is a set of plans for a wonderful little dwarf clock, copyright long expired....
Jim, You wouldn't happen to have bigger scans would you ? These are fairly difficult to read. Sharukh
I do have the information in a PDF format. I can email it to you...it is too large to put here on this site in the PDF format. PM me your email address please...
Thank to everyone on the feedback, I have see the Aaron Willard (Massachusetts) shelf clock new for sale but have not been able to find Dial nor plans. I know Mason And Sullivan had a kit back in the day kit K7698m... Hope some can give me some direction, find it hard to believe all these plan and history just faded away there has to be an archive somewhere ( a keeper of the past). Also want to know if anyone remembers The American Clock Company they where located 83 & North Ave Elmhurst, IL 60126, they had a Dollhouse Collection, plans and part to build 2nd floor, Clocks and Clock Kits 1st floor, also Music Boxes, basement was the seconds... the factory was in Clintonville, WI (if I remember right), never hear about them. Think parents past and the kids sold off everything... so sad. Again another set of plans history lost I have a Eli Terry and Tambour Clock built for my parents when I was in my 20's Hope some can help, would love to build the Aaron Willard (Massachusetts) shelf clock with my boys but need Dial Thank you for your time John
John, It is difficult to tell from the photo, but it appears that the Willard dial is a common round dial and the bezel and gold-colored pattern below it may be part of the front door. If you know the diameter, you might find a suitable dial and hands at Timesavers or Ronell. Do you know any of the dimensions of the case? From that, you should be able to derive the dial size. If the dial and other white trim are all one piece, that is a very unique dial and is probably not something that a clock supply place would have. For that you would need to go to a place like The Dial House and have one made. Another option would be to create your own design with a computer graphics or CAD package and then print the dial yourself or have a photograph printed at the proper size. I had an 11X14 image printed at a local camera shop for about $10 and it came out great. Tried an online photo provider that was much cheaper, but the quality was poor. This is a beautiful clock and would love to see someone build it. Keep us posted on your progress. Allan
The dials on clocks like the Aaron Willard are "kidney" dials. They are generally one piece although I think there are a couple of Willards that have an applied piece riveted on. The clocks in the photos attached are obviously not Willards, very much country style Mass shelf cases, but they may give you a better idea of the dial and surround and movement etc... I don't believe you will find an "off the shelf" dial for one of these. They are generally made of sheet steel, 1/16" thick, with 3 feet riveted through the dial to mount them to the movement, like many tallcase clocks. If I were to build one of these I would start with a proper movement, then make a dial to fit the movement using photos of like clocks to scale the dial. Then send the dial blank off to one of the dial painters to have the paint done. A case could be pretty easily built from photos of similar clocks out and about, or a trip to a collector who owns one would be useful, accompanied by a scale, camera, and notepad. The clock is basically a backboard with seatboard mounting for the movement and the rest of the case is 2 boxes.....the lower case is affixed to the backboard, the upper case (hood) generally slides on and off like a period tallcase. Feet and fret can be pretty easily drawn from photos and worked via normal wood working processes..... I would approach David Lindow for an appropriate movement and I suspect he could supply a dial blank also.
Jim you are correct not a round dial but kidney shape attached nice example, just need someone a place to buy or have made. I will try David Lindow, also found CL Phillips, see site nice close up of fret work and plans at bottom (no detail) http://furnituretoorder.com/clocks.html https://mb.nawcc.org/image/jpeg;base64,/9j/4AAQSkZJRgABAQAAAQABAAD/2wCEAAkGBxQTEhUUExQVFBUUGBcWGBgXFxgVFxUXFRUXFxUWFxcYHCggGBwlHBUUITEhJSkrLy4uFx8zODMsNygtLisBCgoKDg0OGhAQGywkHCQsLCwsLCwsLCwsLCwsLCwsLCwsLCwsLCwsLCwsLCwsLCwtLCwsLCwsLCwsLCwsLCwsLP/AABEIAQQAwgMBIgACEQEDEQH/xAAbAAABBQEBAAAAAAAAAAAAAAAEAQIDBQYAB//EAEgQAAIBAgQCBQcKBAQFBAMAAAECAwARBBIhMQVBEyJRYXEGIzJSgZGyFDNCU3JzobHR0hZiksGCk HwBxUkQ6I0Y LxJYPC/8QAGQEAAwEBAQAAAAAAAAAAAAAAAAECAwQF/8QAJhEAAgICAQMEAwEBAAAAAAAAAAECEQMhMRITQSIyUWEEQnEUof/aAAwDAQACEQMRAD8AL4dgIuii81H82n0F9Qd1Ejh8X1Uf Wn6V3DR5mL7uP4BRQFWQDjh8X1UX Wv6Uv/AC L6qL/AC1/SiVFKRQMF QRfVRf0L ld/y L6qL/LT9KKrqABfkEX1UX Wn6U08Pi qi/y0/SrCHDs5sovbnyHjU0kcUejtmf1Rf8SNvbUSyRjyVGDZULw I7Qx yNf0oqPgKn/ALMQ8UQfhajxiSRZMq9w5acz21F0EzakELcLcnKuu2g7TpvXO/yH qNVhXlgr8CiG6w yNT/AGpicIw55Rf5aVJi HoSuZ49wthZtTfXYke hMVBBCY7yW6SRIV83IBmkvYDq2O21R3cv0V24jsXwuJbZUw7faAjFu0ERsL6jQ2qFcAlrtBGv S3geqdvx7qLxGGUXJlFlG3ROO69yPGoYeHlb5WiccwJACNfzo7 T4QdqJE2ChBymKMHsMY59 Wx99IcBFv0Udj/In6US8 IhJuroOwHMBpzHs5UmDmRsxaLITa5WwudwwA059mtUvyl yol4fhgwwEX1Uf9C/pTvkEX1Uf Wv6VYjBE gc/cRlYeIOlQW8faCPwNdMZxlwZOLXIIcDF9VH/Qv6UnyGL6qP hf0ooimmqJBvkMX1Uf9C/pSfIYvqo/6F/SiaaaYgU4GL6qP hf0rvkMX1Uf9C/pRJFdagZ59xPDoJpbIvpv9Eesa6peK/PS/eP8Rrqko9A4aPMxfdx/AtEih GjzMX3afAKJAqiBwFdSrTgtzagY0CjI8IF60u29gR7jzqeGAIbelIRsNkvtfxrhBcm5vbcnqhb sf7CubJld1E3hjXLIlkaSwRcsd9QOqT4W1v4a1FPgFRSdSVsTGvqA63sbDqgnWpOIyI8JV3aFJiMPmFhKJJDlQA7JZrEW7AdKqvKri82Cgw7hc6RyQfKZBYdXZyF3OY6k8rjtrFR3vbNLovjgzlshWLYrlFzoQdWItY67DnS4nh6NuCxuCCxLkFWDAjNcDUDYUQjA2INwQCD2gi4PtFqeVoYyj8oeIvBh5puiVuhUuo6TQ5djYLcWv6P41W4DiRkwuALgSTYoxsCw0RlVpnmsN8gByrpclRpqasfLZP/wAfi/uJT/41WcA4Z0 A4c6NklgSOSNrZlJyFHjceqy6EjUbiilQm9l/iIWZCqSFHPotlVxm5ZkIsVvuBY9hFZ/yW458uSVJYwkuHkEcijrIxU3DLm2BKkW1q1lxMz3ECxgqSpdmzRhhppZbvlJvYb2sSKg8lfJxcFEyhzJJK5klkIy5nPYvIC599KlQ92GTYbSyMY9VvlNuqDduqbrra23M0JicNrmyXYkWeO6OLnU5NQ1hc78tquDUTg8gD23bLbv2NZsoosTCbBs5cE5Q6XDht7Mg1vuTbvuBTvluYZZTmW/VlTLnW9sptazD2eIqu8n JDH4h5gjR/Jc8Kyq4MbsxPWylbuSlhY6AHfWrefCh3IIVZbAlh6D39HvDGzabj YU3FxetCtSIJYytiSGVvRdfRfut9Bu7Y8jyphFRQYh4XZCtw2jIxFmv8Ar2jfn3GSwrlDxklCcutyVPqsfcLn/wC nDn6tPk55462ga1dTgK410mQw0lOIrqYGB4qPPy/eP8AEa6u4r8/L94/xGuqSj0HhvzMX3cfwLRVDcN Zi 7j BaJtVEjhR8UJQDS8jaqOy3b3XIpvDYBq7eiv4n/SiOiNybDM/PmFXkLnQVzZp/qjfFHyxmGDAkNILt6R0vobHIB6RNwLd47rlwwEHW2XdV9Q7G5Hpk735XI76SCNXVWAJVWut7qUYXuxOhD7g9xI2Jou1ZJUqNDL XPk2cbh2RWIlj85BYkDpANA2upbYHleoPJfii8SwLJOPOWOHxKHQh7WLW5Xtm7iCOVa1hWB43g5cHxWLFYaNpI8ceixESC5LgX6Qa72GfxVu2mt6E9bDf H NcJJgpvnsC/RG/wBOH/sv7tPdWuvVE/BUbGDFpnEgi6FgrZI261/OML5iBYWXs1NXAgv6TFu4XRfcpufaT4VMnsaAPKbD9JhpoS6RmaN4wXbKBmFs1tz4VVw8MmjwEWFhnjV0UI0ojkkBQG5CqBu2xudvGtNHEE9ABb qAt/G29OpdQ6PPsTw3icJR04mkqqVBjeFYBkBsVUOMgsNhcVu4gCLocyjQEHN7yCdakVyNtKjlw6McxUFvWtZv6h1vxpuVglQjLWQ8vOJSWjwOH/9TjOr93DqJHPsuPAGtb0Tj0WzD1ZNfYJB1h/izVTcP4JEmMlxJMhxEyBbSkMUUWv0TAWKmy9u3ealUtg74J DcMjwmHSGP0Ixa/rMfSc95OtJxDiMaITKwSPnfUt3Ko1Y FE4 ZVRiSFVBmZm2UDcmsfBwCTETdPILRuwZQ j9GLFFyfRuBe3K/bWbbuylSLkwGdPOZkL26L1oVPohu1joTrzA5XqDBuVzI2VmKjS90njOxuNwdbHkfCwv0wikNnGYNoRyI7D2juofiOGDZUuS pibfT6Qb WwF772B1IopvfkCoV1vYEkEAqWtmYD0gbbsp0PiDzp5FdhtGCut1JXMDcMjC4V1tzFyO8HxqbFQFGKnl PYa7cGXrVPk5ssOlgxrqVq4VuZGA4r8/L94/xGuruK/Py/eP8RrqRR6Hw4eZi 7j AUWgvpQ3DfmYvu4/gFWXD1AYudQgv4nZR7zTbpWJK3QbIoUBT6EYu38xOoFCx8SHSiJw4d1MoJF0kUAssasNmOpymxNudSC7CzCw1lk10IABK93Jb95qHHcXOEg6eWKU55Ly5es8WYdVsovnVQFGhGxPdXCnezqelRHjfJ3DY1FbEK02dVa/SSIOsLjIqMFA1tt41npPJXF8PbpeGzPLGDd8JKbh1 kEY8/cb8ztUB4ziMMxnwKjiPDpCX6OMnpMK7G7qNC6qSSQCpHKwtroOCeWsWJ0jw MD qYDYHsMl8o8TatPUv4Rpl/gMYs0SSposihhfQr2g32INwfA0nR9IbkWWxA5M4Pfuqmw03NQ4KM5crWtmZmA1BdnLFAearf2kUdes7NEhLaAbW9gpCKU0hqWMYxpRS2riKkZGaVjSqKRxTEKDQmMIIynxve2W30r8rdtSSS20GpO1UMjfKSyg/9Ops7DT5S6nWNeyJTuR6R02vUtgQ4f8A6h42ku2HVrwXFhiZFPVlktyGuUWsxF7bVpFXmdzUccIIIYAgi1thbs02qp48MWELYZ/ORAuEYKVxSDdWNrpIO0EA6aa6OOw4B KYvEy4v5Jh3ECpGss05RZGAdiEjjVtLmx1PfVsY2SMh5HltbrZFEgI2ICABjewtbnVP5NcdTFw/Kl82bdHLcZgpTrBZMtiLZiQ40s2oFVXG/KcYl0wWBb5RJJIhmlRSIookdWbrHf0dTfla5Jq l8E9XktWllNp5YeiBbo5Iswd7HQOxXqg jYC hGtFYqMmxFzlFm xurew6eDd1WWOW7nqkpL1HJIABN8htuTuNuY1oDDMY3ytruP7EfnbuYVCl0TUkU1caK80lE4yDI5XkNvDlUFq9FO0cTVHn/ABX5 X7x/iNdS8V fl 8f4jXUFHovDB5mL7uP4BVthjZQLauTv2Jb 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 qFyrffb8qOlNCt3waBRUeIU2uvpp1l7yNx7Rce2iFSmyC1BRV8B4TDh0PQBgJGMpJYksz6lj2HlptVjc66779/j21FhRbMvINcfZfrD8cwqY0ueRURTxllIFrnQXJA7jp2VWY4ElHO7KG00swIVh8Huq5FAYqI5X20ZrACxAkXNa9zfUjs2oatD8g3E49EYdlr/AIj 9V1qucQg6JgNlykdtrj xNVFq7MErgcuVVI894t8/L94/wARrqXiw8/L94/xGlrUk9D4afMRfdp8Aq6nHVl7ggPsS4/L8apOHfMRfdp8Aq1x50kANjnGvIjov9RWOd6Rpi5ZZwk55db2dVGhG0Ufeb karuKeVODw75JsTEj qWuR4hQbe2oZIsS6SxFkjeScp0sWYmNDGGdgH2bIoUa7tQWE/4e8OW1sMrH1pGeS5O5a7WNZa8mtvwaHB41Jk6SJ0kQ7MhDD3j8qdEfSP8AMfwsP7VmOB TcEQXF4ENAZFDNGGLxTLrdGVjpzysNjY7XB0uDcFbjYs5Hhnax91qiVeBpvyTWritKKU1IwafDK6sjAMjCzKwDKw7Cp0NVMnDJYR/0zgKNoJSWi//AFSavByFusg5KKvDSrQvgGigg8pFDiKdWw8p2WW1n 7lHUk8Lg91XCYkEb28dPzpMdgUlQpIqsjbqwzKfYa8y8oeHxYaR0eV1g6CQpEzO6u5bIUTQn0W2J0vcEWoSt0JukbTjfGSrJFEBJPJ82lxYKD1p5DyjX8ToKI4HwwRrqS7Mc7udDLId3PYOQXkKxnkVAiTMkBVkOHhzlb3DhydSwuA4YuFuQBbU716PENKGqdBF2rHEU0Cn0tqBnKKRxTkrmpgAyMFe5v6B219FhYW5nrGnDpNyqj XMb 8C1 78aj4mxXrAFsis9huQjIzAd9ganw JSRFkjYOji6sDdWHcaSQxM9msTo3o9xA1X27j20JiGZS/8A3L9AbKAtgZSrOSSdFUX77VX V/EHhwmLdN0iDKbXyMxtqPAXHePCoOGRYyxeeeGRGw8RIEJR7nMTqGtmudTsewVSWrJvdFsB1XH8lx7v9KqauQNH xb3A1S1t N7TLPyef8AFj5 X7x/iNdXcV fl 8f4jXV0GR6Hw4eYi 7T4BVnPGT0x5MInHiUCt VqreHDzMX3cfwCtB0OYqBqHisPtDb86xzrSNMXLIxEztKrqFDFHBSRs6kxqoKkILHNG2t/ZVVjfJ3ETXWTiU5gOjRrDBG7A7gzRgGx22q3gmLZCACGTLmzbmNidBbsLUYawcmbUQphwqBEsiKAoA5KBbKOzTnXYcauLbN DKrfmT7qnFMOjjscW9qXI94Le6pGSWppNSGmUAhK4iuNIaQDraUBxLhMU65ZY1kW97ML2I2I7D3ijhS3pgA8P4XFAuWJFRRsqiw0AHidhvRpFOIptMQ0U402uJpAOptLXAUmMhteTT6Kfizf8AwrJ8Q8hz0rS4PGTYEyEtIkYzxOx3cJnXKT7e61a3Da5m9Y6fZXqj8ifbUhFNNrgTSZUcP4FHFA0BLTCQN0rynM8zOMrMxPdYAcrCkMDIrqXzIqQxi6gMbWv1gbcxyq4IqskVmUDMGEj6dUA5UuDexsRtyG9DerGkSE bkJ9Uezq6/iaoqvcVpC57f1Aqiro/GVQMM3J5/wAW fl 8f4jXV3Fvn5fvH I11bmZ6LwweZi 7j Ba0IciOJxulj7NVb8PyrHYzEvHgkZGyMI4gGsCRdQNA2l9qvfIZ82CjuzN1pASxzNcuSbn/F VZZXejTGvIZIWQuqgMVcSqLhRkOj62PInYE9ajwTbW3s29hO9V7vlsxHzLGN 9CAVPf1SD4 FOfEGGORpDmESlrILdQAstiSSxNrezauRG4YaDmxiFuiEsfTABlTMM4I1BK3uAb217ah4b8oCiSeSMN6RiSMdHGNyhcnO7AXBbQfy1kf HmPjh4biMZO4HTzzSOSdXt1VUDdiWJAFUo2JyPQYpgyhhz5cweYPeDceyn1WcPkZYo5JBbPGjSjmjlRdz3cm7ND21ZUhiClpoNSUANIrmNIxpCaQxy1xpBXE00I5jt30hriaaWobAcKB43xFIImd2yrsWsWyj6T2GtlGvuot5QqlmNgNSd/DQbnuqFYM2YyKDnGXIbHKnqHlckXPfYcqNAPwOJjkjDwurxWAVkIZbAaaj8jUKcWhaZ4OkUTJvG3Ucgi4ZAfTUg7res1L5GRiRnwcr4HEi13i1ilB9EvCTltuCBYXF7a1BhOK4xJokxmDjxPSkRw4mLJlAFyMyOPN36zk9XuBqkl4Ibfk2eJPUbe9rCxINzouo21tQXotlBJEKBQSbm52F fIeypsSdmYnzYzEqbBjbQZTcEflcVHg49gb5mPSP3X2FZy2qRogXyrx3QYZermLSwxW29NwGPsFz7KrWGtS XvFxh1wxKh kmKWOlrxOMwNjqCwqF9zXbj4OXJyYDi3z8v3j/Ea6m8W fl 8f4jXVoSb6PCLLhY42LBTHF6JAOiqeYNXvkpgliR0S XPmFzc3Zety/lHvqo4Z8zF93H8Aq 4G2rjuX8zUzSqxxewrGRAEOfRIyuO76Lf4dfYTVR0DswiaVgIr3VQL4iNtApc iB2DU9taFj h7LVU4vDEZbHrITkPap ixty/ICuTJp2jpjvQFxjh808TQJiFiVwA7hC0xjbdQMwVSQCM3jpRXDuB4eFIkSFLQgKhKhmGtycxF7kkn207DTIqZvQW9nBJLLIe0nV82mvhbuOXwIvyO47jU26HSHCoApj9EFo/VHpJ3r6y/y7jl2UQaC4pFM65YJVgJBvKYxMV9ULGxC6k3JN7AbXNwIGGRuCLggg8xzp9YDh3GcVhcSIOIsvnmtDi0VVjkbkkqKAoPf1WHaRrW5zMPTX2pdh42tmHhr4mm1Qk7JCKbSLMp0DAnxF/dvTyh7DUjGE0l6Xoz2GoXxUa6FxfsXrt/Stz FKhkjGop5goBPPQAC5Y9ijmaazs3orkHrPq3sjB IjwNVvHsHMYJBhZOjxDZQsr2J3F1uVIUEclAAp0IKgmDSlX9ONVcJe4jEhYKT6zkKdeXLto3NWM8iMEmFMqS4uOfGTuGlAkBYFVsE6xux1Oth3bVsVND06BbQPj0JUkEgqDe25Q/OKO8jbvAp0soGXLYtvGt7ZtLC3cAb FTsbAsdLa FVWIlGUArldrKkexhC262n0tiCNNhsCaVeRg8GCjiZ1RiIw3SSre6GS vRg jc6ZRp3Xq7wsRALN6T6t3dijwFhQPCcNmObZUJAG4LDck88uuvM FXLDSqxpy9TJk0tFJx1z1B9o/l/rVRVhxxvODuUfiWqtBrthwc0 TA8VPn5fvH I11LxX5 X7x/iNdVCPQ GnzMX3cfwCrPhj2kvyysO7dN/dVXw0 Zi 7j AUdgT52MaalhqCb9RjYW2Om500qZ 1jh7jSA0yaIMLHbl2jvqRaUWrmq0dBncU7pLmAGdRqnKZe1e8X/H2GwwGLVwCgultb7xkaZCOex8LeyisbhFkWzXFjdWHpIe0fpsazk4bDsM1w5JtJ9GTQZeRsTzUjlfvrNrp/hV2X2LxccUZkkdUjUZixNgB299VPBPKEYwFsKp6FWymaQFVZhuscfpORcXJygUrRwYpSk6KxkCXje Q21UL6puCb31PbajOETRhWiij6KOF2hQWyq2TRzGOYD5lvzKmqVULdkk3D1kUrMTMrbq1gh7iigAjxvRWHgVFCIoVVFgqiwA7BTr0ppAMlsfSAPiAfzqrk6NpjCiLmRVeQ6gIrE5FABALtlJ7gLncA2hGuu1edeQ3EJGxnEoWNpmxOYkgErGpdSQDpoAoHLrLQlyDZt/ksYIuitc26wzEE7HXlRqCwsAAOwCw9wrLPiZoOIQwvIZsPig5j6RVzwTRDNYOoF1Knn31pxSY0I1CYhgwKg7Ml/eG/L86LY0DiFKkuCNbAq1wra2U5gCVOtr2I11qWMzH/E7haTYGSUgCTDASRuNCLMAyXHI39hANaPg8z/J4DMfOmCIvf0s5QZtBzzX250HxISSCPzSyxrLGXRWJVQG0lZyB0gjbK5RRyN9qnxOKBbqeckS7GS VUvcHuy76a3t9K1U36dk1vRPNi2VusAxIui3tl73tuOY9o7xBgomfNc9ZrGSTmi2FokHJiOz0R30zh DMhLBjlO8mxc263Rg7DlmPs7r2CIKoVdAP986mKcueCm6FhjCgBRYAWA7ANhUjVwriK6ImTM3x0 ct2KPxuarb0bxtvPv3BR/4g/3oC9bx4MJcmD4r8/L94/xGupOKHz0v3j/Ea6qA9B4afMxfdx/AKsMBIRIluZI9hU61VcObzMX3cfwCrLhjeej8T8DUp 1hD3GnibSpDUcZqQVyx4OlnVHiIVdSrKGVtwdj/vtqWuNUIzeP4KyKehBdeSlusovcgX6rg9mh7c1VGH4 6XicEgWQq4uVuNCBa9u4g9gArdGhcdgo5QBIoa2x2I8GGorNw8opMCwWMjZQsbkEDRW1JsP5rHXx50arNlBK66XCm vO17fnWexnkepJMMzoexrsvaB76HXBY6NmIUuoBC2K3LDQta46p3HO1TclygNFHjFZQestwD1lYaNtuLbVRY7h HOIXGxypFMqkMxsyTRW1SRbgg22caiw0NQR8dxi26aBlItoEIzduuov4dldJ5RSpZRHoV0Ww21GTNbfT8aXWkx1Za4YRTNDiswa0ZMQU9UCcA59QDnKhRrtc9tHLiQVuoLErcCx3tcC9rVR4LykB6iqqheqoIYWVdF2W22UWH9qfNxCdgohRmGt8qMuVeWrWF96XV/QotpJS0dxZAyaMzAZcy6Gw7NOdVmIxqMuVryMy6oNFBI18bHnqKTD8PncedjAPrSSd2hVIvyJouDgagWZmYeqvm18NDmI8TSfU EO0VWJkmkboyCSLebXK1xtdzfKosOZO9xaruDh1xaWxXfo19C npHd9RfXTuNGwQqihUUKByAsKkAqlDdsVi0opBTxWiJGinGkFKa0iSzJ8dFp378p/wDED 1V96M46/n3/wAPwiq/NW8eDnlyYfinz0v3j/EaWmcTbz0v23 I11MZu Hv5qL7tPgFWXCz56P7RPbsjGqnh3zUf2E AVb8FHn4/FjsfUbs2qZcCjyapKltTFp9cyOoW9dSU2S9jbfl407AcTTDQ8szBRoCxvfWwsDa9CzaHNYXAuAb6ja5t3nTwNZyyUUohk0mh2J7CbeNQyzEKLG1rX0zewX/ADoDEYK9rjOW3Y8tOzlr2dlZwxzYaTIszujIZF6S0novkkRtAdCVIYEHrEW0rF5JbbG6Rr34mAQADrfc223t7xvbeiYpiQTYgdpI1G9xbl41l8PxlCLSgITtm1Xl6LW7RzAI7KtUxeoJOmhAtvYg32sRa/40o5vLY leC0aXS4Ph2UNHj1NxrmG47 wUEMYNr3UgAjmSR1rdgGp9tV/EOJxRLm3JsF0u75QbAaXbf0tttdKJZlqmHT8l7PiwutgNsxP0dOdQxcVic9SRXtvlIb4dq85xE0 KvIwHRhgEDdZMxYKion/ecswGY9UGiofJ3ECziWMunWQCECxHLpQbi ova3jR3JMi/hHo8UgIuDcUqTA7HaqiGbKzLyPZrlPPxFSREEjItgbEmxF7Xv7TemsjZfSW0bg6ipaiSn1vFmbFpxNMBpSa0TE0Y3yiP/UP4J8AqszVa US fbwX8qqiK6FwcsuTE8T ek 2/xGkruJ/PSfbf4jXUDNxw4 aj wnwCrvgNzLpf0W1FurtrY79ntqj4efNR/YT4RWg8mfnT9g/mtKftCHuRpxTqatPrnR0iUh76caSgCvxkGtwcp8RrrroQddKjGFvqCddr3udNSTY21/KjYsQrbXIuRqCNVax3HbSSzWtlGZm2F7eJJ5AVj0RbsvqAzG4FzlAXXTrd5Ow8azHlFwMTP0zB5EijKmMOYzkDGRnXLY59zY3Btbq71tZHCi5Nhpr3nQDxJoHHZiw6pAIK33N23GUa7X3tvUyjQ9S0zzvF4bDx6RYmZLgNZW6bqmxVirKbAg6ZjVOpltIYHmyQqzsXcqhKgtYpGctza2S5OuthWx4l5HrlVID0OWxKOXZWF XXYg68tO3kQ7F8Gf5O8SFCpR0CBMi9ZSNwSV1IuxL9/bXOlKHm/6aNY nS2ZybE4qYxuJ8vSIoygIg6W2wa1lzDa lxa tAOksV3nw8jdrSMSh1 kY9GHcxrTcM8m5TAqSNk6oDIoD2vr13IYX12A05E71bYHgaHLnczuBYZwoygCzHLqt/5rXN9xVdLutV/wBJxSVeuN/0znCMZicTJFkVFRGjkLAFrBHuigZtzZxbkATpYX2sMBzC dNzl6vt1F78rG4pcHwwxkhFRQxLFlAQkkBdcgGZgBuRe3M1YJhlXUKAdr8/fVRxJccFTnbtA0uE06lr6gA6AXFtCNe jIo7d9SIKfWyiuTJsbSh6400VQhwNLem35UpqkxGY8qF86p7UH4Ej9KpSKvvKhetGdLZWA7bggn2aiqI10w4OWfJh J/PS/bf4jXV3E/npftv8RrqoZtOH/NR/YT4RWl8lV60h/lUe0kn 1Zvh/zUf2E EVrfJfD2Rn5u1u6ydntY1GR kMa9RdrTgaYtKDXOjpoUnSml7C57LnnSk00oNuXZyobAjnmyrdVLk io mSLgX2UdpOwoThCyHPJIb5iFTTKCq3LuByVnZgP5Y1POrGm2FyQNTa/fl2HduaAoZNEGKk/QYMPEAj/wDo0KmIMjuq3VI2yO/Nn0LRpfkLi79ug1BsUrdp17LAe7tqOJWzMxsF io7b3aRj6x7BoAOZOiAC6CMyEk3K3Wy3AjuMzZm5vYAkk6C23MmR4sqhiMpKqgseszC6hebEgE6cr3pw6NgyjKQ1yw5HMbknxN6fLCGsSAbA27sws2t Y0pa5K2BQzqSuQ5Yy7WIBvK4vnCjlGttX22A750mQaZhcZiToPQALseQAuLnvrpTFGMzZUCplve1kXXKvcNNB3d1CT4JCuWKNAWVUu1yEUHMCwPpEElsp3bfmaKQthscquAVJIOx1GYWvpztrUGOnEYS305EjC tmOth3C7f4a54kyBM2hIQHNZmbNqMw1LFhr261MIgGzaliLXJufZ6o7hakMkDcuf 9aeTUQOvfUiikJnCuJpW0plMB4FOIpi04mrQmUXlPbInbnIH9JJ/Ks2TWs8oYrwsealWHsNj DGslW Pg58vuMTxI ek 2/xGupOJ/PS/bf4jXVoI3PD181H9hPgFbTgqZYI/At72JrFYJvMxn/ANtPgFegYVQEQDYKoHMbDY86yy8F4uSVacBUbSUglvXPaN6JDQOIxlmAAJ56G1 Xj7akxGIA0uLnvsQLbgc6AdutqpL2TTn1Ra22oP8Aes8k/CKjESbrOjFnUjYHq 3TffanSYshSGYk75gMtx7KmfBWUWHe1yWHba2vvFVmNjJW1yB38vf6XttWMuqKbo0VMsMMwkZTfa9xvcjQXPgdu j5UJFlIHiL8tLa9tqzWEkWK5Ru xuPG3 lWo4mxUHIw7TlLad1jVYsqr1ckyjvRHBhjHlCsQqx9HoF9IW65HbzttqabipbghHkGurgjNuDkUEW5AXttftqOXFFycgJJ7QB d6kbDMoDN1jY3sNFAF etr /ak5t30jr5A1BafpnJJQjKuSwVNQEGbfrWcmwJIXsAFi0LMoAmcasWNhmObl/KACbW7jyoSdToB1jnym3cqhj4Cwp0U7LoQRr2dneAR Aohka9wOK8BEGCK2s9gGvlA0EagiKJbnQD0i27EnYaU3ELIEv0tiAxYhRYknRVB9EAG19zYU35fz0AHIKxJ9v lC4vGFjbRQP8RPsG3 9KqWVUSohmDxCopBzGxJG1gvJR7jvfnrUwkZhc5lHYBr7aEwsF7WF fO3iT/AGot4HFitie/Qeykupq2PQ3DYlj6XWA3O1hci/f/AK0dG9xcCwofCYfKDmOYtv2eAqZYgCTrr36C ptWsLS2TKh5pDStSsK0JA8XFnR17VP5ViBXoIFYLFpkdkP0WI9x0/CtsXBhlRhuJfPSfbf4jXV3Ej56T7b/ABGkrYg3PBIswgUalhELHbZd/ZevRJbnb/Y5VivJCOzwFtAIwQTsT0dh da9sfGPpE/ZVm/IVjlV6NMWtkgiFPqvk4t6sE7HwRL 13091Bz8VxBByYQA9skynXwQa su2/Bp1oubilMlv8AdqyzT8QOwgXbkWI27Trz99CTYbiDG5xAX7Coo E01ikJ5EbTPTe3TfuvWLl4fjmNzin0va1l339EDsoWXyfxDeliJDv9N dgdj3Cq7TF3fo3qqRpY/jTVw4X6NvHU 86156fJSQ2vI5ttdnNvDrU1vIoHc3t23P5mjs/Yd76N yqpvdRfSxIG wFRHEocy9Imm4zLdRbnr3GvPZfIJT6v9AP96iH/D1OeX gfrR2PsXefwejQQBRp2sb6bubsR2XNLKl9TcDQA7E328dSK83HkCBoCB/h0916evkOdLOdNt9LbW62lL/AD/Yd5/B6EIWXm1uW4/0PupWcL1rWtz7OW/jWAHkX2t fv3qaPyVddpCN72uL3vfn3ml/n x976PQlJ76cW7awcXAJl0EzjwZwNNufcKfFwbEJfLiJBffrNrfxNPsv5Du/RuOkHbTi9YpcFjBtiX07bN8QNTwPj1NzKjjTR415crqAaO1IO6jVu mldGaz3/ADPGjeGBx3M6H 9HYDij3tJhnQE ksiSADkSDlbs2FS4STKU0y3rGeU0FsQx9cK3ttY/lWrGMQ8yPFSv lUPlSmZo2TrHKwNuViCL 81pjuzPJuJ5VxEedk 23xGlp/Eoz00mn03 I0lbmRruH VkqxRgRxaIg2fkoGvXon Mpvq4fc/766upjFHllN9XD7n/fS/xnN9XD7n/fXV1IDv4zm rh9z/vrv4zm rh9z/vpK6gYv8ZzfVw 5/wB9J/GU31cPuf8AfSV1ACfxjN9XD7n/AH0v8YzfVw 5/wB9dXUIBD5YzfVw 5/300 WM3qRe5/30tdQA3 L5vUi9z/vpP4wm ri9z/vrq6kBw8sJvq4vc/764 V83qRe5/311dTAQeWE3qRe5/3138YTepF7n/fXV1IBR5YTepF7n/fXfxhN6kXuf8AfXV1ACfxhN9XF7n/AH138XzepF7n/fXV1AWMbyvm9SL3P mHytl ri9z/vrq6mIxvEOMu0shypq7HY82PfXV1dTA//Z Four examples of shelf clock, my fav is the 3rd one, most were made with matching shelf, not many examples found this way Thank you to all who replied still on my search and will share when I find the sources John
Want to share this also link from Garrett Wade Carlyle Lynch's Measured Drawings of Classic American Furniture http://www.garrettwade.com/carlyle-lynch/a/103/ Carlyle Lynch Clocks http://www.garrettwade.com/beds/c/13583/
I think that Woodcraft purchased Mason and Sullivan. They were selling a few kits for a little while. Perhaps it didn't do well for them because they stopped. Maybe an inquiry could bring back plans?
I bought a number of Carlyle Lynch Clocks plans years ago. I found them not to be very good in a number of respects. Others may have different opinions but I do not recommend them.
I just saw this thread, and I have a few things to add that I think will help you out... I've made about 30 weight driven clocks over that last 11 years. All but one were of a Willard design (Banjo, Girandole, Lighthouse, large-dial regulators, and one tall clock)... No Mass shelf clocks though ! Some advise: First off, if you want to be as authentic as possible, the only source for a movement at this time (and I'm pretty sure he can supply the dial also) would be David Lindow out of Pennsylvania (a Google search will show his web address). I spoke with him about a year ago. He makes "Willard authentic" Mass Shelf Clock movements. He makes them in "batches", so it may be a "hit or miss" proposition, i.e. you might have to wait a while for them to be made. Expect to pay a "good price" for them also. Your money WILL be very well spent though. He makes "a superior product" ! With a clock of this type & design you'll want it to be "heirloom quality", and with a Lindow movement, that is what you'll get ! Hold up YOUR end of the bargain, and a family heirloom is assured ! I mentioned "Willard authentic" earlier. For a Mass shelf clock movement this means: 1. the movement is weight driven, 2. the pendulum is "on the back of the movement, NOT on the front like a Banjo movement". (I have seen Mass Shelf Clock repros using Banjo movements, and all I can say is "they are just NOT correct" ), And last but probably most important: 3. The pendulum has an approx. 10" drop. The standard Banjo pendulum has a 20.5" drop, so IF you used a standard Banjo movement, your Mass Shelf Clock will be too long... There are original Willard clocks of the basic Mass Shelf Clock design that have "tall base sections", but NOT with Banjo movements ! ) When I started out making clocks I bought the plans from the American Clock museum in Bristol CT for the "Aaron Willard Banjo Clock". While I mostly conform to the plans as illustrated, I have "Improvised" on them. Example: On the plans, the top of the Banjo Clock throat is too wide. I narrowed it considerably. This makes the clock MUCH better looking in my opinion. That's the ONLY deviation from the plans that I've done. (Actually, Lemuel Curtis, a Willard apprentice in the 1815 timeframe did the same thing ... Consider also: If there is one design of clock out there inwhich it's dimensions are pretty much "a constant", it's the Banjo Clock. It's construction just about requires you to conform to "plans" due to the "standard-ness" of it's dimesions. The Banjo Clock looks "out of whack" if it does not conform almost 100% to the proper "Willard" dimensions. To your advantage, this is Not So with the Mass Shelf Clock ! It's dimensions varied considerably yet stayed within certain "limits". In my estimation, all you have to do is get the "basic dimensions" of the clock, i.e. overall height, width of the clock head section, width of the base section, depth of the clock head section, depth of the base section, and then the height of each of these two sections. Actually, you could "look" at a picture of one and estimate the height of each section fairly well. From there, haunt a few of the websites that have pictures of the Mass Shelf Clocks by Foster Campos, Elmer Stennes, or even the antique originals. Take a look at how the clock is constructed. Except for the top decorative elements, and possibly some OG feet, the clock is nothing but "right-angled cuts" and a few sections of moldings where the clock head and base sections meet. The first thing to do is contact David Lindow and get the movement. Let us know how you make out ! Joe
Joe, Just a follow up I did know about David Lindow and in talk on some movements, yes very fine quality> I also met someone who worked for Bartley Collection and know a of a person (older lady) who hand paints Clock faces, when I receive this information will share. Question you stated that you have made many clocks ... Banjo, Girandole, Lighthouse, large-dial regulators, and one tall clock, may I ask where you bought your plans, or where can I download or purchase. I am always looking, but hard time finding this, sad because in the 70,s - late 80's these where easy to find purchase for cheap. Thank you for the info John
Jim, I am just finding this thread, and wondered if you'd still have the pdfs of these plans, and be willing to send them to me? I'd be most grateful. Thanks, Jeff Brown
Here are the plans I have, lets see if it will work in the new MB SW? Looks like that is not a good idea. Hmmm, PM me your email address and I will send you what I have.
Hi guys, Lindow still makes movements. The 'older lady' is Martha Smallwood who has sadly passed away. However her daughter Kathie is still painting dials. As for authentic Willard plans contact the Willard House & Mueseum Where time began in the Blackstone Valley. Some of the designs will need to be slightly modified since there is not quite enough room for the back cock on a Lindow movement. Another alternative would be to ask David to reduce the back cock length by 1/4 inch as he does for Leonard Marshark.
Thank you very much! I hadn't checked back and just saw that you had replied. I appreciate your kind help.
