A very unusual Waltham - circa WWI?
Discussion in 'Wrist Watches' started by Jerry Treiman, Apr 6, 2018.
  1. Jerry Treiman
    Jerry Treiman Registered User
    Aug 25, 2000
    6,053
    1,040
    Geologist - California Geological Survey
    Los Angeles, CA
    I was very excited to finally get one of these rather uncommon Waltham wrist watches.
    It seems military in style, but the protective device for the crown does not really seem very practical for rough use. If you can’t tell, the bow holds the crown down so it cannot be pulled out accidentally. The case is also kind of a hermetic design. The 6/0 (Jewel Series) movement is fixed in a ring that also holds the crystal, and the entire assembly is installed from the rear and protected with a threaded-on back, so it is just a two-piece case.
    So far I have only seen eight different examples of this model, and that includes the one shown in the Price Guide. Five are in solid gold and three are in silver cases with some gold elements to them. My biggest personal quest with these is to figure out who made these unsigned cases. Most are just marked “PATENT PEND.” and a 4-digit serial number, plus the gold or silver marking. I would also love to work out when these were made.
    Does anyone else have one of these?
    Rick Hufnagel, musicguy and pmwas like this.
  2. Adam Harris
    Adam Harris Registered User
    Moore NWCM Award
    May 3, 2012
    3,200
    78
    Jubilado (retired)
    Costa Blanca - Spain
    Hi Jerry
    It is indeed a very early and interesting piece, similar in thought to DEPOLLIER
    Suggest you contact Stan, who. he and I did research on a similar piece he had.
    Regards
    Adam
  3. Steven Thornberry
    Jan 15, 2004
    21,155
    721
    Ne’er do well
    Here and there
    Working on the suggestion of ca. WWI and the mention of the movement being fixed in a ring, I wonder whether the following patent is applicable.
    US1088097.pdf
  4. Jerry Treiman
    Aug 25, 2000
    6,053
    1,040
    Los Angeles, CA
    Thanks, Adam. Yes - Stan* was the first person I thought of and we have both been puzzling over this model for a while. The watch case has some special design elements that are reminiscent of features patented by Depollier and also by Ezra Fitch (Waltham’s president). The case construction and finish are, in some ways, similar to cases made by H.W. Matalene but also very different in other ways.
    Steven - thanks for the suggestion. The method of holding the movement in the case (the focus of the patent) uses a “locking bolt” (patent figure 3) This was used on Waltham watches with the Marsh movement protector but is not used here. My movement ring has three dog screws that retain the internal movement assembly in the case.
    *for those who do not know who "Stan" is, this is Stan Czubernat who has written separate books on Elgin and Waltham watches associated with the WWI era.
  5. Adam Harris
    Moore NWCM Award
    May 3, 2012
    3,200
    78
    Jubilado (retired)
    Yes, it is between Era Fitch patents and Depollier.
    If Stan has not seen it, then its pretty rare - he surely has done the greatest research in that area.
    Sorry, I can not help more - sadly all my files are still in Spain too.
    Good Luck and keep us informed
    Regards
  6. Jerry Treiman
    Aug 25, 2000
    6,053
    1,040
    Los Angeles, CA
    Here is an example in silver, and in remarkably original (though worn) condition. It is more evidently intended for service in the trenches than others I have seen (such as my gold example, above). It has a black dial with radium numbers and hands. The silver case, including the (probable) gold lugs, is coated with a non-reflective finish that I think is more than just tarnish. (For example, black tarnish on the gold lugs would be hard to explain). This watch has not been “improved” in any way by collectors or previous owners. The original unbreakable crystal likely shrank and fell out and I have added a temporary glass crystal to protect the dial and hands from further abuse.
    What has been most illuminating for me in studying this watch is finding it still has the remnants of some type of seal between the movement “pellet” and the crystal opening in the outer case. I would guess it was either a rubber gasket or some kind of gum or pitch that is now black and brittle with age.
    This seal, the threaded back (gasket missing) and the compression crown suggest this watch was meant to be water resistant. It may be that the pending patent (as announced in the back of the case) was for this entire assemblage of waterproofing features, or maybe just for the crown. I have so far been unable to find any issued patents matching the features on this watch case. I suspect it was made between 1917 and 1920 but have little yet to go on other than a hunch.
    Another aspect of this watch that is very new to me is its condition -- well used but all original, representing how this watch was made around 100 years ago. The strap is tearing a little and stitching has come undone, but I would not want to replace it. The black dial with radium numbers would be very difficult to restore without risking further damage and non-original reconstruction. The hands, too, show light corrosion and partial loss of the original lume. I really do not want to scatter bits of radium paint around, either. The movement is mechanically sound (it will tick), looks free of debris or dust, but is obviously a little gummy. I am nervous that removing the dial to clean the watch may risk damage to the dial and/or hands (the hour hand is very tight). The screwed-on back of the case has remarkably fine threads and the silver feels soft; it does not thread on/off easily and I am loathe to expose it to the possibility of cross threading or other damage, so I will open this as little as possible. So where does this leave me? I have a very interesting and probably rare watch that, for the first time for me, may be better off left in as-found condition rather than my usual cleaning and “touch up” to make a serviceable watch. Right now I will do nothing more to “improve” it.
    I would love to hear from any other collectors who may have a similar watch.
  7. Adam Harris
    Moore NWCM Award
    May 3, 2012
    3,200
    78
    Jubilado (retired)
    Hi Jerry
    Pretty sure Stan had one of these and it may have been posted here
    a
  8. musicguy
    musicguy Moderator
    NAWCC Member Sponsor
    Jan 12, 2017
    4,716
    2,164
    New York State
    These are really great watches Jerry. I'm glad you
    added them to your collection and shared them with us.
    Rob
  9. Jerry Treiman
    Aug 25, 2000
    6,053
    1,040
    Los Angeles, CA
    #9 Jerry Treiman, Dec 16, 2019
    I am still searching for evidence regarding who may have made this interesting case. The closest that I have found to a similar case was discussed by David Boettcher on his web page dedicated to “The evolution of the waterproof watch” - The Evolution of the Waterproof Watch
    About halfway down this web page he presents information on the Fortis “Aquatic” waterproof watch. The method of holding down the crown is not quite the same (but almost equally as awkward). However, the concept of an encapsulated movement and crystal sealed in a two-piece case is very similar. A patent application for this design was made in 1915 and a Swiss patent was issued in 1916. If my Waltham watch case is referring to the same Swiss patent it would apparently date to that same time period. Alternatively, the “Patent Pend.” notation may refer to an attempt to apply for a U.S. patent, perhaps a few years later. There are, after all, some differences such as the bow and the method of retaining the movement capsule in the case. The case markings and construction details of the Fortis and the Waltham appear different enough that I strongly suspect different case makers.
