A sad Accutron index wheel
Discussion in 'Watch Repair' started by Chris Radek, Sep 11, 2019.
  1. Chris Radek
    Chris Radek Registered User
    Apr 13, 2014
    588
    196
    Watchmaker (now accepting new customers)
    Lincoln, NE, USA
    Where mechanical watches just stop when run for a long time without service, Accutrons are strong enough to keep grinding away. Here's the ruined index wheel and pinion from a 2181 that was recently on my bench. The watch was still keeping time pretty well, but starting to lose a bit, leading the owner to send it in. The upper pivot has a shoulder worn into it, and the lower was spinning in a pile of rusty grit that filled the space between the jewels and wore the pivot into a point. Sometimes I find pivots stuck in the jewels, twisted clean off, probably when someone puts a battery in after the watch is sitting for a long time.
  2. Skutt50
    Skutt50 Registered User
    Mar 14, 2008
    3,577
    132
    Gothenburg
    Interessting.......
    I have an Accutron that humms but does not run. I have looked at it several times but never had the right feeling to take it apart.....
    (So many small adjustments and I only have a loupe for magnification.)
    I must get my act together one day and dig into it......
  3. Chris Radek
    Apr 13, 2014
    588
    196
    Lincoln, NE, USA
    I have serviced so very many of them, but I would not attempt without my microscope...
    It's tough because needing service is not seen in the performance of the watch. You have to do it on a schedule, the time to service it is when it's still apparently running perfectly! Not an easy thing to convince people.
    Rick Hufnagel likes this.
