A little more shame
Discussion in 'Clock Repair' started by TEACLOCKS, Apr 21, 2017.
  1. TEACLOCKS
    TEACLOCKS Registered User
    Mar 22, 2005
    1,469
    Clock service & repair
    Santa Rosa Calif.
    Back plate you might not be-able to see, looks like the bushing came out and the guy used some strips of some kind of steel and poked them down next to the pivot then soldered.
    The front plate some kind of solder then panted #2 wheel strike side
    And solder caps on to barrels
    GREAT
    [​IMG][​IMG]
  2. R. Croswell
    R. Croswell Registered User
    6,644
    24
    Another example of taking more time to mess it up than it would have taken to do it right the first time. This crosses the line of what might be considered a "hard times 'innovative' repair" and reckless damage.
  3. shutterbug
    34,360
    31
    Here's a similar one I have on the bench right now!
  4. Tinker Dwight
    Tinker Dwight Registered User
    13,680
    Such poor soldering is also noted. At least they could
    have done a better job of soldering.
    On the first one, one wonders what the arc of solder does?
  5. R. Croswell
    6,644
    24
    Look close, I believe there is a little piece of metal in the pivot hole but surely didn't need that gob of solder.
  6. JTD
    JTD Registered User
    Sep 27, 2005
    3,951
    19
    Yes, I can see it too, there is a piece of pin or suchlike soldered to the plate, I guess it keeps the pivot where it ought to be.........it's truly awful, but I can't help admiring someone's ingenuity, I don't think that would have ever occurred to me as a way of 'fixing' a worn pivot hole!
    JTD
  7. bruce linde
    bruce linde Technical Admin
    1,778
    don't disagree, but think that's understating it... gross 'repairs' and a complete cluelessness about clock best practices and hygiene. the bar is low for creating that 'here's how it cleaned up' shot. :cool:
  8. Tinker Dwight
    13,680
    On TeaClocks' one, does anyone notice the lower left of the
    barrel cap?
  9. TEACLOCKS
    Mar 22, 2005
    1,469
    Santa Rosa Calif.
    1st picture back plate, If you look close the bushing looks like it is missing, then a tin strip is inserted in the hole then soldered.
  10. kinsler33
    kinsler33 Registered User
    Aug 17, 2014
    625
    Science teacher, writer
    Lancaster, Ohio, USA
    This might be an Asian clock with very thin plates--thin enough so that the winding arbor bushing tore out.
    M Kinsler
Similar Threads - little more shame Forum Date
Walnuts and little cups of kerosene Clock Repair Oct 15, 2017
Kroeber Newton Missing Escapement Parts and maybe more Clock Repair Aug 21, 2017
What can you tell me about this little German clock? Clock Repair Mar 11, 2017
Hand Tension: Too much, too little, just right? Clock Repair Aug 6, 2016
Need a little advice about Hermle 451-053 grandmother movement Clock Repair Jan 15, 2016
