20th c A Lange and Söhne Glashütte Dresden Regulator Spanner
svenedin
Jan 28, 2010
1,749
478
Surrey
Another of my watches. It needs a bit of fine regulating. The adjuster is a square with no screw slot. I am wondering what would be the best tool to use. I believe there were special spanners made for this.
gmorse
14,032
3,172
Hi Stephen,
Do you have anything that would make a slot to fit that, such as a piercing saw? If so, cutting a short slot in the end of a piece of brass, (rather than steel), would be the easiest way if you can't source the proper tool.
svenedin
Jan 28, 2010
1,749
478
Surrey
Hi Stephen,
Hello Graham. That's a good idea. I don't really have a suitable saw at the moment but I could get one. I had thought a balance screw holder might work but I think the angle is too awkward (I haven't actually tried this). It's rather a special watch that I obviously don't want to harm in any way.
This watch still has its (possibly original) protective pouch.
gmorse
14,032
3,172
Hi Stephen,
That's why I suggested brass. Those screws are quite delicate and any sideways pressure must be avoided, so a slot in the end of a short length of brass rod or strip should do the job.
svenedin
Jan 28, 2010
1,749
478
Surrey
Hi Stephen,
OK Graham. I will try to fabricate something. It's very unlikely I will find an original tool. This watch is an absolute joy to behold.
svenedin
Jan 28, 2010
1,749
478
Surrey
I think the serial number dates this watch to about 1912.
Dr. Jon
Dec 14, 2001
7,191
1,535
New Hampshire
I would try to use a watch key. If the handle on the key interferes cut off the end and put it in a pin vise.
If this does not gain good access the next trick is to slice across the key to it os open on two sides. This will enable you to hold teh square from teh top and tourn it.
Usually this type of screw has two holes one in each direction . A pin goes in to turn a 1/4 turn at time.
Reactions: Bernhard J.
svenedin
Jan 28, 2010
1,749
478
Surrey
Yes I have seen the type with a hole for a pin but this one does not have a hole. I was thinking about trying a watch key as you suggest.
175,175
1,532,122
52,603
Jerm346
1,063
2,972
