A good rinse for shedding water on parts after ultrasonic cleaning...
doc_fields
Sep 29, 2004
1,324
37
Greentop, MO
precisionclockandwatch.blogspot.com
This idea is not mine, but learned it from David Labounty some years back. I use a 50-50 mix of Xylene and odorless mineral spirits for my second rinse. Any water drops left on the movement parts after the first water rinse (to wash off the ultrasonic fluids) immediately fall off the parts and drops to the bottom. Drying after that is a cinch, as the 50-50 mix dries rapidly with a heated blower.
At some point, the 50-50 mix can be carefully poured into another container, keeping an eye that the water drops in the bottom do not go into the container, then discard the remaining water and solution, wiping out the original container with a paper towel for any residue. The 50-50 mix that was poured into the second container can then be returned to the original for re-use. All safety precautions, of course, should be followed per the instruction on use of the products.
Secondly, when rinsing with water, you'll get a lot less water marks and staining if you use either distilled water or reverse osmosis water for rinsing, especially on the nicer, higher priced clocks and such.
Hope this helps a little, especially for those that are new to clock repair!...........................gary
bangster
19,971
503
Thanks, doc. I whomped up a batch of LaB's mixture a while back, but retired it because of the xylene smell. Couldn't stand it.
Not a reason for others to avoid it. It works as advertised. But my initial batch is sealed in a can somewhere off in storage, where it will probably spend its life.:eek:
R&A
Oct 21, 2008
4,203
107
I just use alcohol after a hot water rinse.Wipe all parts off with a cotton cloth. Not spots and dry in a dryer. I stay away from chemicals that need to be avoided and need special care in handling.
Reactions: bebem
5,099
637
I don't think the xylene is actually needed. Odorless mineral spirits should work just as well.
mauleg
Dec 26, 2012
848
144
Like bangster, I'm not a fan of Xylene. I've found that compressed air (hold onto small parts so that they don't fly away), followed by a blow dryer is adequate. Good point about the distilled water, doc!
R. Croswell
11,048
1,149
www.greenfieldclockshop.com
Xylene has fumes that I can't stand. It is also quite flammable. With a proper vent hood I suppose it would be tolerable. Can't pour it into the sewer, and probably shouldn't pour it on the ground. With compressed air one should at minimum have an inline water separator and remembers to drain it as needed.
Has anyone tried Jet Dry or similar dishwasher products to help water run off? I wonder if they leave any residue behind?
5,099
637
I have tried it. Probably used too much but I noted an interesting effect that let me to discontinue using it. I had cleaned some blued steel parts, hands and screws, and after the rinse the blueing was gone. Just a clean steel surface was left. I had to re-blue the parts.
166,306
1,449,005
86,808
TopherDale
2,910
