A German Made clock?
orso
Jun 9, 2013
226
72
Minnesota
Bought this cheap clock at an auction. It looks like still working both time and strike side. I'm curios to know what it is; the are no TM stamps on a serial # on both plates and on the back "12/200" tha I assume is related to the pendulum length. Bezel and glass are not attached but I have them. The bezel opens from right to left. The The spring are in barrels from which the main wheel can be detached for maintenance. IMG_1570.JPG IMG_1571.JPG IMG_1572.JPG IMG_1573.JPG IMG_1574.JPG IMG_1575.JPG IMG_1576.JPG IMG_1577.JPG IMG_1580.JPG If "12" is the pendulum length cannot be in inches, so looks like not an American clock. Is it a German clock?
brian fisher
Jan 20, 2017
1,750
436
houston, tx
For me, it’s hard to say who the maker is without a stamp on the movement. I think it appears to have been made in the 1930’s or perhaps early 40’s? I don’t think this sort of “luxury” would have been made during the war effort, so it probably was produced either before or after.
If it is German, before the war is most likely.
Burkhard Rasch
Jun 1, 2007
4,942
209
65
Twistringen
afaik it was Kienzle who used the bajonet cap barrels in their lower cost line.German industrial movement with quick-out barrels in any case,made early between the wars.12cm pendulum length,200 bpm.
Burkhard
orso
Jun 9, 2013
226
72
Minnesota
Thanks, Brian. I was intrigued by the movement, new to me. I think it only needs cleaning: has been running for 3 hrs now.
orso
Jun 9, 2013
226
72
Minnesota
Thanks, Burkhard. This thing is exactly as you described it. I found it interesting the barrel feature.
chiminIn
Aug 17, 2016
20
China Grove, N. C.
the gong hammer, coil, and movement look like a smiths enfield that I have, they are made in England and are usually marked so on the dial. just my opinion
chronologiker
Jun 28, 2017
360
27
Greetings Orso,
I think it´s German and it was imported to GB about 1937, when German clocks were prevented from the British market by special tariff of duties. And therefore your movement/clock has no logo. But the case might be British.
If the dimensions of your plates are 102mm x 85mm and distance between the plates 37mm, it´s a URGOS UW 700. Please prove.
Chronologiker
new2clocks
Apr 25, 2005
3,401
529
Pennsylvania
Greetings Orso,
Chronologiker
Chronologiker,
Around 1922 or so, British law required clocks and movements imported into the U.K. to be marked "Foreign", regardless of whether or not a trademark was imprinted on the movement or dial face. This leads me to assume that the clock is either not German or , if it is German, it is of an earlier vintage, such as the very early 1920's or of the decade of 1910 to 1920,
Regards.
Steven Thornberry
User Administrator
Jan 15, 2004
23,481
1,507
Here and there
Chronologiker,
Regards.
You seem to refer to the 1926 supplement to the Merchandise Marks Act.
But, one question to the group: How do we know this clock was ever imported into the UK?
new2clocks
Apr 25, 2005
3,401
529
Pennsylvania
Steven,
I do not think we have confirmed that the clock was imported into the U.K. To avoid confusion - my response to Chronologiker was based on his assumption that the clock was German and imported into the U.K. If his assumption is correct, then the date of manufacture would need to be prior to 1926 (thanks for that correction of dates).
To be frank, I think at this point, we can only opine on the origin of the movement.
Regards.
chronologiker
Jun 28, 2017
360
27
Indeed, I was wrong: it is not shure that this clock has ever been exported to GB.
On the other hand, we know German movements of that time with the mark of British makers. And I assume there are also unmarked German movements of that time that have been smuggeld to GB.
But I think this movement was made by URGOS about 1935/40.
Chronologiker
orso
Jun 9, 2013
226
72
Minnesota
Thanks, Chronologiker and New2clocks for the infos.
Sorry for my late answer; had eyes surgery and have not been playing with clocks or PC for a while.
Yes the plates are 102 x 85 mm, in addition all the levers are steel and the main spring covers are brass plated steel. Maybe steel was cheeper than brass or was brass needed for other uses.
new2clocks
Apr 25, 2005
3,401
529
Pennsylvania
Orso,
Hopefully your eye surgery was nothing more than a Lasix procedure, and hopefully everything is good with your eyes.
Regards.
orso
Jun 9, 2013
226
72
Minnesota
Hi, thanks. Yes, things seem ok for now. I had cataracts removed and bifocal lenses implanted. I was able to drive the day after, but close vision is not ok yet. It seems it take time to adjust.
orso
Jun 9, 2013
226
72
Minnesota
Just a curiosity: I had to cut both barreled springs just below the holes; on one of them it was stamped "HK". Maybe a clue to the maker?
46,719
1,913
Hard to Know.
Just ignore me! ;)
Reactions: orso
orso
Jun 9, 2013
226
72
Minnesota
Back to a possible identification.
"Hidden" under the basel door I found a clue that if not the maker identify the country of origin. It should be a German made clock; There it is marked " DRGM" that should mean :"Deutsches Reichsgebrauchsmuster" - "Design Registration valid all over the Reichs".
May be Chronologiker can confirm?
new2clocks
Apr 25, 2005
3,401
529
Pennsylvania
Orso,
You are correct. This pertains to a type of German patent.
Regards.
Similar threads
166,352
1,449,405
86,827
kawasemi
2,911
NAWCC Forums Rules by Steven Thornberry
