8 Day cuokoo clock Pendulum Problem
Discussion in 'Clock Repair' started by Gay Laster, Jul 13, 2018.
  1. Gay Laster
    Gay Laster Registered User
    Mar 9, 2015
    32
    cuokoo clock 001.JPG My problem is to keep accurate time I have to raise the leaf or bob so high you can't see it . The movement is a Regula 74/1/76 . I'm not sure this the original movement for the case. Any suggestions would be appreciated. cuokoo clock 001.JPG
  2. rodlloyd
    rodlloyd Registered User
    Mar 16, 2010
    99
    10
    Sterling, Kansas
    I suspect it is not the original movement. It looks like a pretty big case. Can we get a picture inside the case from the back.
    Rod
  3. Willie X
    Willie X Registered User
    12,774
    984
    Many 8-day cuckoos have hidden or almost hiden pendulum leafs.
  4. Chris D
    Chris D Registered User
    Sep 8, 2009
    467
    20
    Coplay, PA
    If the leaf is roughly in the middle of the stick and it keeps decent time, that's just the way it was made. If you wanted you could order different wheels that will give you a longer pendulum length. I'd have to double check but I think on the Regula 34 (8D), you need to change the chain wheel and the second wheel (you'd also need a longer stick).
