8-day clock Gaining Time
Discussion in 'General Clock Discussions' started by Gary J, Sep 21, 2002.
  1. Gary J
    Gary J Guest
    I have collected pocketwatches for many years and have now been bitten by the clock bug. My first project is an old 8 day mantel clock marked All British Made Perivale which strikes every quarter hour with four rods and hammers. I dismantled and cleaned the movement and it is now running and striking, but is gaining about 10 minutes every 24 hours. The suspension spring was missing and I replaced it with a new one. Could an incorrect spring be the problem? Also, having no serial numbers, what is the best way to date old clocks? Any suggestions for a novice would be appreciated. Thanks, Gary
  2. Gary J
    Gary J Guest
  3. Gary J
    Gary J Guest
    Doug,
    The pendulum is adjusted to it's lowest or longest setting. Is this correct? Thanks for the reply, Gary
  4. MikeP
    MikeP Guest
    Asumming all parts (especially the pendulum)are original - a BIG assumption with old clocks - then it is likely that the suspension spring replacement is the problem.
    Was it exactly the same length as the old? If shorter it is possible that there is now insufficient movement available to move the bob down the rod sufficiently. Also it's possible that the new spring is too stiff which will speed up the clock - again possibly too much for the bob adjustment to correct.
  5. Gary J
    Gary J Guest
    I believe all the parts are original other than the suspension spring. It was missing and I am guessing as to the proper length. This is probably where the problem is and I will try other springs. Thanks very much for the help. Gary
  6. Pete Riegel
    Pete Riegel Registered User
    Sep 6, 2000
    473
    I had the same problem with a ST #2. I ran out of adjustment with the bob adjusted as high as it would go. I solved the problem by shortening the wood pendulum rod by 1/4 inch, which put the length in the mid-range of the screw adjustment. It worked fine.
    Pete Riegel
    150665
  7. Pete Riegel
    Sep 6, 2000
    473
    My reply was not responsive. For the problem described, it will be necessary to lengthen the pendulum rod a bit, not shorten it. A longer suspension spring could do the trick.
