English 6 Pillar Regulator Movement and Dial
Discussion in 'General Clock Discussions' started by 12lb weight, Jun 7, 2019.
  1. 12lb weight
    12lb weight Registered User
    Jun 3, 2019
    45
    31
    Still alive, takes all my time
    Norfolk UK
    Good Afternoon All.
    Some help requested please.
    Acquired some years ago, but has sat on a shelf in a box all but forgotten. I decided to make a start with a view to making a case to suit. Probably a curved top long case in Walnut, but I digress. The movement is quite nice with jewelled pallets and maintaining power, but I cannot place the dial. The reverse side has many inscriptions of various services and overhauls, the most prominent being that of P Richards, January 7th New York in 1820, but also Joshua Parks Coventry GB 1866. There are many indistinct others so the clock is well travelled , but lacks any makers identification. The movement is very substantial and the dial is 12 1/2' Diameter.
    Does anyone have any thoughts on this being of American origin ??
    Thak you very much P1080556.JPG P1080557.JPG P1080558.JPG P1080559.JPG P1080560.JPG P1080561.JPG
  2. novicetimekeeper
    Jul 26, 2015
    9,866
    623
    Dorset
    It is surprising that it had screwed pillars so early. I don't know much about regulators, apart from them usually being expensive. It has that awful metal cable Americans like but it is very new so not original. Does it have a grooved winding barrel?
    I have seen those pillars before but not screwed.
  3. Snapper
    Snapper Registered User
    Nov 30, 2014
    288
    Lincolnshire, UK
    All my instincts say this movement is English and the shaped plates hint towards the early nineteenth century but as Novicetimekeeper says, I have never come across screwed pillars so early. Could the pillars have been drilled and tapped at some time, or even replaced altogether as the screws and washers look rather crude in comparison with the motion work.
  4. 12lb weight
    Jun 3, 2019
    45
    31
    Norfolk UK
    #4 12lb weight, Jun 7, 2019
    The barrel has shallow grooves. Totally agree about the cable is has to go. Looking closely, which is hard to do on photos, the pillars look original and the spacers/washers have been machined to an accuracy that make me think that these have always been there. If someone was able to machine these to that degree of accuracy they could have machined the pillars.Strange not to have a name on he dial though.
  5. 12lb weight
    Jun 3, 2019
    45
    31
    Norfolk UK
    Should have mentioned that the Pendulum has a glass mercury jar ,adjuster AND micro adjuster, with a Invar steel rod. The pendulum hangs on the backboard and luckily I have the fixing. When I bought this around 1980:???: it was a project, now it it an ambition .
  6. 12lb weight
    Jun 3, 2019
    45
    31
    Norfolk UK
    Just thought that I would try this and interestingly, the piller screw tightens up all the way to secure the piller without the washer being in place and this is the same on all 6., rendering the use of the washers totally unnecessary.
    Bit of a puzzle why they were added, but the marking on the plate suggests may years or from origin. Beginning to wonder if the dial is an earlier dial fitted to a Victorian movement, if so, excellent job and wish I had those skills.
    Any thoughts on this aspect ?
  7. bruce linde
    bruce linde Technical Admin
    6,585
    741
    oakland, ca.
    this is a completely subjective rather than informed opinion, but when I first saw the post and initial photos I thought that the washers did not look as refined as the pillars and also look like they might have an even thicknesses… although perhaps just the photos.
    I like the look of the washers better than without… I will leave the question of originality to those who know more what they’re looking at.
    by the way… That’s a nice movement to have sitting around waiting for when you can get to it
  8. 12lb weight
    Jun 3, 2019
    45
    31
    Norfolk UK
    Thanks Bruce, but it was more of a case of my wife moved the box to a deep cupboard under the stairs and I forgot about it than anything else.
    Memory getting bit shot these days, so better get that case made while I still remember how o_O
  9. Jim DuBois
    Jim DuBois Registered User
    NAWCC Member Sponsor
    Jun 14, 2008
    2,825
    566
    Magnolia, TX
    Any thinking that is T. Richards, not P. Richards? Thomas Richards did offer a regulator. I think I saw one at auction awhile back but have not found it again. And the signature looks more like a T to me. Both his tie to English clockmaking and his tie to Simon Willard suggest he may have been dealing in better grades of clocks, perhaps regulators.
  10. novicetimekeeper
    Jul 26, 2015
    9,866
    623
    Dorset
    I would say it definitely is not a P. I could not quite decide what it was though, it has similarities at the top to the J.
  11. 12lb weight
    Jun 3, 2019
    45
    31
    Norfolk UK
    I have looked in Loomes and there is a Thomas Richards in New York in 1805.
    Thanks Jim, I will see what else I can find out.
    Holmcroft
  12. zedric
    zedric Registered User
    Aug 8, 2012
    1,136
    152
    Maybe buy a Scottish roundhead longcase and use the case for the movement. Might be cheaper than getting one made, if you can find one that fits?
  13. Ralph
    Ralph Registered User
    Jan 22, 2002
    4,836
    126
    Regulator cases have unusually thick backboards. 1 , 1-1/2", maybe even thicker.
    Ralph
  14. 12lb weight
    Jun 3, 2019
    45
    31
    Norfolk UK
    Well it took some time , but the case is virtually finished. Like Ralph suggested a 1" backboard and I have hung the pendulum from it. Took a while to source a suitable mercury jar pendulum and the fretwork needs a little finishing, decided to discard the old dial as this looked much better and was looking for a home P1010307.JPG P1010308.JPG
    D.th.munroe, brian fisher and JimmyOz like this.
  15. zedric
    Aug 8, 2012
    1,136
    152
    Lovely work on making the case!
  16. novicetimekeeper
    Jul 26, 2015
    9,866
    623
    Dorset
    you had another dial where everything lined up?
  17. 12lb weight
    Jun 3, 2019
    45
    31
    Norfolk UK
    No it did not line up , so I filled the tiny original holes with brass studs and sanded and polished these down on the face and reverse of the dial. drilled new ones, turned new dial feet and fitted these with the original screws., then resilvered the dial and applied 2 coats of lacquer. The original screws were very small with minute countersinking which was not to difficult to replicate. The movement is a 6 pillar one with 4 non concentric dial feet.I have cut out the mahogany fretwork below the dial and fitted it, but am in 2 minds about carving it ? The fretwork was cut using a tracing taken from a clock I found in a museum having kindly been given permission when I explained my reasons for wanting it. P1010309.JPG
  18. Raymond Rice
    Raymond Rice Registered User
    Feb 14, 2011
    284
    26
    Retired IBM manager, retired politician, now just
    NYS
    Very impressive work! Congratulations on completion of your beautiful regulator.
    Ray Rice
  19. brian fisher
    brian fisher Registered User
    Jan 20, 2017
    1,468
    326
    houston, tx
    wow. as mentioned, that is incredibly impressive work! did you do all of the work yourself?
    the last tall case on my collection list is an astro regulator.
  20. Ralph
    Jan 22, 2002
    4,836
    126
    The clock looks great. I have a stray case that looks like that. It has had some heavy restoration, but has a great glass, with Greenwich Time gold leafed on it. It had a nice fretwork as well, but I had another better clock, missing the fretwork, so it got reassigned. The case looks like an astro case, but I as am sure it was what I call a gentleman's regulator and probably had a time and strike, deadbeat escapement, maintaining power movement. It failed the thick backboard test, plus had two holes in the waist floor for the weights to descend. I'm looking for a stray movement, lto marry into it. It can be a lower end , non jeweled movement. I have a good movement, but it's too good for the case. LOL.
    Thanks for sharing.
    Ralph
  21. Ralph
    Jan 22, 2002
    4,836
    126
    I know of an 18th century pagoda topped musical clock with screwed pillars. I would put it around1780-1790. Thyar Pitt, London.
    I wonder when they started?
    Ralph
  22. novicetimekeeper
    Jul 26, 2015
    9,866
    623
    Dorset
    I've only seen them as repairs to older clocks before, I have no idea when they started.
  23. THTanner
    THTanner Registered User
    NAWCC Member Donor
    Jul 3, 2016
    2,606
    191
    Carson City, Nevada
    I wonder what the thread pattern on that might be? Many screws, nuts and bolts of that era were machined with no standard thread pattern considered.
  24. Jim DuBois
    Jun 14, 2008
    2,825
    566
    Magnolia, TX
    A quick scan of Derek Roberts books on precision clocks shows several people using pillars retained by bolts/screws in 6 posted movements by 1780. Of course, he also shows some using pinned posts as late as 1880, so, while some thought the bolts were necessary, or a substantial improvement perhaps, some others thought not.
  25. Ralph
    Jan 22, 2002
    4,836
    126
    Stubbs, Martin, and others provided screw plates and taps to the clockmakers and others. It's a good idea to gather an assortment of screwplates, if you work on early clocks. They could come in handy.
    Ralph
  26. 12lb weight
    Jun 3, 2019
    45
    31
    Norfolk UK
    Thank you, Yes all my own work. It has taken me over 70 years to get here since my initial interest in clocks as a child.
    Still learning new things as I go and being prepared to try anything ,(with many mistakes along the way), always helps.
    I would love to make a replica of a late 17th C Marquetry case, but a suitable movement is very hard to obtain.
    Getting the movement would be the 1st step and having enough time to complete it would be the second, maybe a lowering of sights is required ?
    I have always been intrigued by the Scottish Fluted Column Drumhead longcase, and have 2 in my collection, but making my own,now that would be a challenge!
    Keep safe and well
