400 Day Wurth Wheatsheaf
ivancooke
Mar 3, 2009
327
Banbridge, Northern Ireland.
Bought this Torsion Clock on everybodys favourite Auction site.
Had a few problems getting it to work. But with a little patience, have got it to function as it should.
Thinning s/spring down from 0.0045, and within the next few days should be keeping time.
A well worth while project.
Serial No. 1198.
Same number on base of pendulum.
Kevin W.
23,152
556
Nice one Ivan, would love to display one like this.
ivancooke
Mar 3, 2009
327
Thanks Kevin, Ken. It's not every day a clock like this comes along, so thought I'd have a go.
Always wondered how the Wille temperature pendulum adjusted to varying temperatures.
The middle stem coming up from the base has a loose sleeve. This sleeve seems to be made from a temperature sensitive metal. When the temperature changes it pushes the upper arms, that are hinged with pins. Raising these arms or lowering shortens or lengthens the suspension spring, and thus making the clock go faster or slower.
Ingenious !
marylander
Sep 9, 2008
877
Maryland
Ivan, Thank you for the illustration. It is nice to see the upper arm in two different positions. Please confirm that the upper arm moves up at higher temperature.
Ming
ivancooke
Mar 3, 2009
327
Yes Ming, I presume a higher temperature would make the metal expand to shorten the s/spring , and lower temperature would make it contract back to normal.
I set the illustration up manually, just to show the effect.
Ivan.
Burkhard Rasch
Jun 1, 2007
4,941
208
65
Twistringen
What a wonderfull clock!Congrats!!Did You ever-or could You just for illustration purpose-put that pendulum in a freezer or "heat" it a bit with a hairdryer to see if this concept actually works?
Burkhard
ivancooke
Mar 3, 2009
327
I tried it and it worked.
The first photo shows the pendulum at normal temperature.
I then hit it for about 3 - 4 minutes with a hair dryer, and as you can see in the second photo the arm did rise between 1 and 2mm.
Certainly proves the point.
Burkhard Rasch
Jun 1, 2007
4,941
208
65
Twistringen
Great,that´s what I expected.Thanks for the pics!
Burkhard
Similar threads
166,293
1,448,901
86,795
Michael Spencer
2,910
