400 day clock
clockman230@comcast.net
Jan 30, 2005
205
i have tried everything!!! the clock runs fine without tension, but when the hands are put on, it runs for maybe 2 hours then stops. what suggestions do you have?
Jan 30, 2005
205
Jan 30, 2005
205
Jan 30, 2005
205
RL
Mar 28, 2004
1,822
pamacm,
You can also go back to the main page--scroll down and you will see the "400 day and torsion clock" forum. probably get lots of replys there.
RL
Mar 28, 2004
1,822
pamacm,
D
DrewV
That's not a huge surprise. These clocks are notorious for being sensitive to adjustment.
You can't tighten up the hand nut like you do with "regular" clocks. You have to have it "just snug" so the canon pinion has virtually no friction on it. Try loosening the hand nut until the hands slip on the shaft, then tighten up just a hair from that point to prevent the hands from slipping.
If that works fine, and you still want to tighten it up a bit more, then you can always keep tightening the nut a little bit at a time until the clock stops, then back it off again.
D
DrewV
Reactions: happycusa
168,949
1,474,237
48,668
Mishellmcgee
2,955
