..........Then, grasp a pendulum arm firmly and carefully and slowly pull it outwards from the bottom which will bend the adjusting extension in the direction needed. Repeat for each arm until all are as close as you can get to what is in the second photo. At that point you should be able to bring your clock to time.
I am a little bit worried about doing this - the adjusting nut/disc is surely under great pressure with this method? The pliers method is a bit (very!) coarse, albeit with no pressure on the disc/nut.
At present, I have improved the running of the clock, and it runs about 1 minute slow per 10 hours, which makes me quite optimistic. Still, the adjusting disc/nut is at the extreme of regulation, so perhaps further pliers treatment would bring it to the middle range.
What would you advise: more pressure on the extension arms (so far no breakage!!!), or rather go for the 0.084mm spring?
Also, is there any literature where I can view these J. Link clocks?
By the way, the balls on your photos are very attractive; are they of porcelain?
