Clock Torsion 4 ball Gustav Becker
Discussion in 'Parts Wanted' started by Paul Snyder, Aug 5, 2020.
  1. Paul Snyder
    Paul Snyder Registered User
    May 20, 2018
    19
    Plumber
    Looking for 4 ball Gustav Becker 400 day anniversary clock pendulum
  2. etmb61
    etmb61 Registered User
    Oct 25, 2010
    2,525
    175
    Retired Avionics Technician
    Mascoutah, IL
    Hi Paul,
    That's not the easiest part to find loose. Are you missing a pendulum or do you just want the ball version?
    Eric
  3. Paul Snyder
    May 20, 2018
    19
    Plumber
    Ya I’m sure of that. I bought a Gustav Becker bandstand clock online auction didn’t notice it had a made up four ball pendulum
    etmb61 likes this.
  4. etmb61
    Oct 25, 2010
    2,525
    175
    Mascoutah, IL
    What is the number on the movement?
  5. Paul Snyder
    May 20, 2018
    19
    Plumber
    Do you know if the bandstand clocks came with a dics pendulum. The number is 4946
  6. Paul Snyder
    May 20, 2018
    19
    Plumber
    I have a mother movement with matching pendulum it’s number is 876. It’s a disc pendulum. Could I use that movement would it be period correct
  7. KurtinSA
    KurtinSA Registered User
    Nov 24, 2014
    3,707
    152
    Aerospace Engineer (Ret.)
    San Antonio, TX
    Some pictures of both clocks and pendulums would be great to see...including good pictures of the back plates. Gustav Becker offered a 4-ball pendulum beginning about 1915. Not sure what was the usual pendulum after that, but I suppose it might have been customer choice?? It might be difficult to know what pendulum might have been fitted. The only thing one would know for sure is if the disc pendulum had a matching serial number which indicates they left the factory together. I don't think all disc pendulums had serial numbers on them.
    Kurt
  8. Paul Snyder
    May 20, 2018
    19
    Plumber
    i will post some pictures as soon as i get it cleaned up. its all a part right now. if thats true that they didn't start using for ball pendulum untiil 1915 than this clock had a disc pendulum , Because this clocks serial numbers date it to 1850 to 1860. and i did google gustav becker bandstand clocks and it shows pictures with four ball pendulum and disc pendulums
  9. KurtinSA
    Nov 24, 2014
    3,707
    152
    San Antonio, TX
    If the serial number is simply 4946 and not preceding by leading zeroes, then it sounds like the clock was built very near the end of Gustav Becker production before Junghans took over the company. I think you found a website that references old production dates by Kochmann.
    According to this post, your clock dates to likely in 1932.
    Post Your Gustav Becker Clocks Here
    Kurt
  10. Paul Snyder
    May 20, 2018
    19
    Plumber
  11. HTomas
    HTomas Registered User
    Nov 2, 2018
    13
    Watch and clockmaker
    Slovakia
    If you want a 4 ball pendulum I think I can help you.
  12. Paul Snyder
    May 20, 2018
    19
    Plumber
    That would be great
    Thankyou
  13. Paul Snyder
    May 20, 2018
    19
    Plumber
    The other thing I need for that clock is the suspension that has the pointer for adjustment. They had that rigged to
