3R12 Battery, 4.5 volts
Discussion in 'Electric Horology' started by John Hubby, Jun 22, 2002.
  1. John Hubby
    John Hubby Senior Administrator Emeritus
    Sep 7, 2000
    12,278
    219
    The Woodlands, TX
    Does anyone know where to buy the above battery in the U.S.? I've checked several websites with no luck.
    This 4.5 volt battery is used in some European battery electric clocks, and can be used easily for Tiffany Never-Wind as well.
    Known makers are Philips, who call it a 3R12, and Eveready who call it a 1289.
    John Hubby
  2. John Hubby
    Sep 7, 2000
    12,278
    219
    The Woodlands, TX
    John Hubby
  3. Rod
    Rod Guest
    John,Just a thought but 3 standard dry cells in parallel will give you 4.5 volts...they are 1.5 volts each.A rechargable dry cell such as the ni-cads are only 1.25 so you should use one of the alkaline battery types,
    Rod
    NAWCC # 0058915
  4. Rod
    Rod Guest
    John,I meant three in SERIES, not parallel!!!
    NAWCC # 0058915
  5. Julian Smith
    Julian Smith Registered User
    Sep 1, 2000
    823
    John,
    Get a radio shack catalog and look in the back for odd batteries. Don't ask the clerks.Most of the ones I have talked to only know what is stocked on the shelves.
    I had to go to three stores to get two
    1 1/2 volt EN6 batteries for a self winding clock.
    Then I had to order them and pay extra for shipping.
    They might not have what you need but may have something you could jury rig to fit.
    J Smith
  6. Andy Krietzer
    Andy Krietzer Registered User
    Feb 21, 2001
    771
    These have "4.5 v. NORMAL" written on them.
    **Duracell Alkaline MN1203 3LR12
    **Energizer Alkaline 1203 3LR12
    **Ucar (non-Alk.) 3R12
    The local "Batteries Plus" store has the Duracell ones in stock for about $7 or $8. Check the bigger battery specialty stores. I don't know if Batteries Plus has a website or not. I believe the batteries are made in Europe.
    Andy.
  7. John Hubby
    Sep 7, 2000
    12,278
    219
    The Woodlands, TX
    Andy, thanks much for the info. One thing I should have mentioned in my original note is that there is not room enough for three D or C cells inside the clock I need the battery for. I have used three AA batteries in series OK, but was looking for "original equipment".
    The clock I'm using the batteries for is a Telavox torsion pendulum electric, made in Denmark from about 1947-1955.
    John Hubby
