34 inch jungens wall clock no weight need cat gut?
ogee_guy
Apr 16, 2006
214
76
this is missing the weight have to see if timesaver has it need new string can you use fishing line needs some other small things is it about 1890s? be a vienna regulator? of sorts has a plain case big pendulum jungens low res 001.JPG jungens low res 002.JPG jungens low res 003.JPG jungens low res 004.JPG jungens low res 005.JPG jungens low res 006.JPG
Randy Beckett
May 23, 2012
2,555
Mt. Pleasant, Tx
Nice vienna type time only clock. A braided nylon or kevlar fishing line will work very well as a replacement line. Gut line was likely used on these clocks because it was the best material available at the time. However, there are better choices available to us.:)
Support the NAWCC
Forum Expense plus NAWCC
Goal
$1,000.00
Received
$360.00
36%
Host server
$250.00
Software support
$250.00
NAWCC operations
$500.00
Expenses
181,330
1,582,210
54,774
Jim Lampros
3,126
Top
